Door hinge issues. - Page 3 - Fiberglass RV
Old 11-14-2017, 10:37 AM   #41
Put a new ball in the lower hinge and a used old smaller ball in the top hinge. This should be enough to get you back in play.
You can also make a washer to sit under the lower ball out of milk carton plastic. this will conform to the shape of the ball and socket. This will also lift enough for the lower ball to contact the door hinge and bear load.
As for the bolt being too long a couple of stainless steel washers or a deft touch with a grinder on the bolt end will correct that problem
Old 11-14-2017, 10:47 AM   #42
Bob,
The lower hinge needs to be on an angle because the arc of the body shell leaves the hinge pivots out of line. The hinges are offset in a vertical plane in 2 directions. That is also why the hinge pivots are balls and are spring loaded. The pivot points are a compromise due to body and door shell design. Its not like a standard door hinge where the door hinges are on the same plane and in line with each other.
Old 11-14-2017, 02:22 PM   #43
noted
steve
thanks for the notes I just had it in my mind to leave the angles alone it just seems to me to be a geometry thing in order for things to line up. I am going to use your ideas I know things are not right as I can pick up on the door and it moves up some.
I hope to get the repair kits soon.
thanks
bob
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door hinge/molding RicK M Classified Archives 0 10-07-2006 10:25 PM
outside door hinge ss bushing rebuild jim munson Care and Feeding of Molded Fiberglass Trailers 7 09-03-2006 05:43 PM
Door hinge Spacers Legacy Posts Problem Solving | Owners Helping Owners 0 07-11-2003 07:45 PM
Replacement door hinge Legacy Posts Problem Solving | Owners Helping Owners 7 05-27-2003 04:22 PM
