door hits belly band. - Fiberglass RV
Old 05-24-2013, 05:57 PM   #1
Trailer: 73 Boler
Figure the title says it all. When I open the door on the boler and it opens over half way the door rbs on a part of the belly band. What have you guys done to stop or avoid this.
Thanks
Please check out my Boler / life blog
http://adventuresofus20xx.blogspot.ca/
B-Rock is offline   Reply With Quote
Old 05-24-2013, 06:06 PM   #2
Well, I have a Scamp with the same issue and I've done nothing to stop it. However, I do hang on to the door when opening it and when I plan to leave the door open, I use the door holdback. That alone leaves about 1/8" gap between the door and the belly band. I wouldn't leave the door open without using it. YMMV
http://shop.scamptrailers.com/p-321-door-holdback.aspx
After owning the Scamp for 10 years, so far... so good.
Old 05-24-2013, 06:17 PM   #3
Byron I do as Donna does but it sounds like you may have a sagging door issue if your door is hitting the belly band and its only half way open....
Old 05-24-2013, 06:38 PM   #4
Trailer: 73 Boler
Sag is fixed temporarily. I just did a cable fix for now over this coming winter it will be a full on rebuild.
I will see if I can find something like that Donna locally, I hear scamp sucks for shipping. I do need something if I plan on using the screen door I plan on installing.
Side note, android app sucks. Could not attach picture.
Old 05-24-2013, 06:39 PM   #5
Trailer: 73 Boler
Second side note. Looks like it did it twice?
Moderator's note: fixed.
Old 05-24-2013, 08:21 PM   #6
If you call Scamp on their 1-800 number & not order from them on-line you will do better. On small items like that just ask that it be mailed to you - no duty if its under $20 so they dont need to send it to you via UPS for their duty services.
Old 05-24-2013, 09:30 PM   #7
chse's Avatar
Trailer: 13' Scamp
When I open the door of my 13' scamp and fix it with the holdback it hits the bellyband and the door flexes a bit. Does this not happen with other scamps?
chse is offline   Reply With Quote
Old 05-24-2013, 09:34 PM   #8
not on my 92
Old 05-24-2013, 09:52 PM   #9
Brian B-P's Avatar
My Boler is the larger 1700, but it is generally the same body, door, and hinge design. My Boler's door will hit the belly band if opened as far as is shown in the photos. Some sort of holder is required; mine has a holdback like the one Scamp uses.
Old 05-24-2013, 10:57 PM   #10
Trailer: '77 Scamp
Doesn't happen on my '77 13' Scamp.
Otters is offline   Reply With Quote
Old 05-25-2013, 07:37 AM   #11
Shouldn't hit. Consider moving the hold back and it's catch a little closer to the hinge. OR There are extended holdback arms available that may be longer than the one you have.
Old 05-25-2013, 08:00 PM   #12
Trailer: 73 Boler
I don't have a holdback arm, going to try and find something local.
Thanks for all the help guys. It's great to have this resource available 24/7.
Old 05-26-2013, 06:49 AM   #13
Byron, just a suggestion. But before you mount a holdback, make certain the door hinges are in excellent shape. I'd change out the pin and brass ball first. Eventually it has to be done because they wear out and if you do things in reverse order, the holdback may NOT line up correctly.
Old 05-26-2013, 09:29 AM   #14
I had a problem of the wind catching the door and springing it open ( 1975 Trillium) back against the ctr trim and trying to spring the hinges. I added a bumper door stop (tenis ball on string) and solved the problem. If I want it to stay open I use a bungie cord as well .I remove the bumper while in transt.
Ron
RRJR is offline   Reply With Quote
Old 05-26-2013, 02:16 PM   #15
Trailer: 73 Boler
Already done Donna, thanks for the heads up though.
Old 06-02-2013, 07:46 PM   #16
Roy in TO's Avatar
You can make your own door holders very easily. Check out the bottom of this page:
Door Holder
Old 06-02-2013, 08:14 PM   #17
IllAnnoy
No it doesn't happen on all Scamps. I am vexed by the same problem. The primary cause is placing the holdback too far from the hinge opening. I intend to make a new (longer) holdout which will solve the problem, since moving the holdout would leave unsightly scars.
Old 06-03-2013, 07:46 PM   #18
The only fault I have with mine is it's mild steel. If I was going to buy a new one, I'd get stainless: RV Designer E226 T' Entry Door Holder - 6" - Stainless Steel
Scamp door rubs on belly band - John Carter Problem Solving | Owners Helping Owners 12 06-20-2012 08:29 PM
Belly Band Leaking? BruceG Problem Solving | Owners Helping Owners 6 04-30-2012 07:55 AM
Belly Band Ruth C. Problem Solving | Owners Helping Owners 2 06-19-2011 07:17 PM
Belly Band repair Johny Bg Problem Solving | Owners Helping Owners 4 05-14-2010 07:55 AM
Trillium Belly Band freddie b Problem Solving | Owners Helping Owners 0 05-04-2010 07:01 PM
