10-07-2014, 10:11 AM
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
door leak
We have a 4 month old Scamp '13 and have noticed after a rain the bottom inside of the door is soaking wet (water can be squeezed out) for about an inch up from the bottom. It appears that the foam door seal acts like a sponge and the fur liner wicks the water up. So far, no evidence of leakage or wicking elsewhere along the door perimeter - only the bottom.
We discussed the alternate rubber door seal with Scamp when we ordered it and they talked us out of it. I'm thinking that was a mistake.
I plan to call Scamp to discuss the problem but thought I'd first check with the forum for any advice or experiences you have that may be helpful. Anyone else have this experience?
Thanks
10-07-2014, 10:23 AM
David
Is it getting wet from just sitting in the rain or is it getting wet when towing down the road?
Eddie
10-07-2014, 10:28 AM
Vermont
Just parked in the rain does it.
10-07-2014, 10:57 AM
Dave
I'm sure you are just seeing wicking due to the inward curvature of the door. As long as it stays dry at the thick part of the door about 2" up and the floor is dry it should not be a big deal. Road spray when traveling down the road also causes the problem. I know several people who have painted the bottom several inches of their door rat fur black to cover up the dirty road spray stains. Water won't bother the ratfur, fiberglass or trimloc. I'm sure you will get other opinions.
Eddie
10-07-2014, 11:05 AM
Vermont
Thanks Eddie. It doesn't seem to be more than an inch and no issues with wet floor. I was concerned about potential unsightly discoloration or mildew on the rat fur. Maybe I worry too much: "keep-the-new-scamp-looking-new" syndrome
David
10-07-2014, 01:35 PM
David,
Dont take "NO" for an answer from Scamp. You tell them you want the "D" seal and have them send it to you. I ran into the same thing as they use "open cell" sponge to "seal???" the door.
On the second day of ownership, I pulled in a crosswind/rain. I could run my hand down EACH side of the inside of the door and probably rung out over a pint of water!! I knew I wasnt going to have it.
Now, the VERY bottom of the door (rat fur) is exposed to the OUTSIDE elements! Why Scamp does this is still a mystery but they do. Yes, you can clean the ratfur but eventually, it becomes very nasty-looking.
I include a link here to my Flickr site of the photos of my "fix". It shows where I replaced the door seal AND created me a "kickplate" that protects the bottom of the door. Mine Scamp is nearly 5 yo now and the inside ratfur on the door still looks new. But it took effort to get it there!
Scamp will tell you to wait a few months (I waited 6) before installing the door seal so the new door can cure. I havent had one minute's problem with the door seal and it still works very well. Take a look and let me know if it helps... (I have some other mods in there as well...) Be sure to post if you have ANY questions and I'll help the best I can...
https://www.flickr.com/photos/503516...7626474795019/
10-07-2014, 02:01 PM
Vermont
Darral,
Great advice, Thanks. Excellent pics of your kickplate. I think I'll do that as well. Did you just drill out the original rivets and replace them after installing the plate? How is the "D" seal attached to the door frame? I'm sure I'll have more questions once I get into this, but for now thanks for the help.
10-07-2014, 02:48 PM
David,
My kickplate is actually VERY basic. It's a piece typical aluminum flashing apx .019 (little over 1/64") thick. It was left over from a shop I built. It's very easy to shape as you can see from the pic. The funny thing is, it's not actually attached. It was a tedious project, but I actually took a piece of wax paper and traced around the door trim and that plastic plate you see there. The height was just picked arbitrarily..but enough to get it up away from the bottom sponge seal (which I still use ironically!).
The next trick was cutting it oversize with enough to stick down behind the trim and the rubber/plastic plate. As can be expected, you cant stick it far because of the rivets. In fact, if you will zoom in, you will see where I cut out for the center two rivets. NOw, with all that said, you may be ok drilling out the rivets, tucking the plate down in there and re-riveting. But it wasnt necessary for me. THEN, I use clear silicone rubber and run a bead all along the trim and alum. plate. One thing I failed to mention, you can also work the top of it down into the rat fur a bit and let it do a natural lap-over and it will help secure the stop and give it a permanent look.
My Scamp has been apx 6000 miles with this mod and 4 yrs without a problem with it.
The D-seal has it's own backing-- like a professional grade of 3M Super-Heavy Duty double-sided tape. It holds very well. The hardest part of all was removing the old sponge seal. In fact, some of the super thin double-sided tape that came off the old seal actually stayed on there. I just applied my seal over it. No problem. I think alot of people use "Goo Gone" to help remove it.
One word of caution. When the seal comes in, roll it so that it doesnt kink and crease. Those creases will still be there when you get ready to apply it if it stays that way long enough.
There is one other problem worth mentioning some of us have run into with the D-seal. Not being enough at the top or maybe some other places around the door. I simply used some thin super heavy duty (rated for outside use) double-side tape to help stand the D-seal away from the Scamp's door facing a bit until I got it to seal properly. You can tape the seal up temporarily, shut the door and get inside and look out around the seal. The light will show up around the door. You might want to block the light around the window to do this. But this is a sure-fire way of making sure it seals! (It was necessary for me to go through this to get the 100% seal I sought after)
For what it's worth, this is just my way of "skinning the cat". Some have used plastic/nylon for the kickplate successfully. Some have even applied the D-seal to the door and not the frame. What I show you is my preferred method. There is something to remember, you'll want to apply a light coat of silicone lubricant of some kind to the plastic plate/seal at the bottom when you first install the door seal. If you dont, the door/plate will immediately try (and most likely will) roll the d-seal right off at the bottom when you close the door the first few times. But once the door sits shut for a long time, it will naturally flatten and you shouldnt have to lubricate it anymore....at least I havent.
10-07-2014, 02:52 PM
Vermont
good tips Darral - many thanks. We're getting pretty cool here in Vermont so this may have to wait until spring, but I'll keep these notes for then.
10-07-2014, 05:40 PM
Trailer: 2010 Scamp 16
Where did you get the D-Seal? Was it from Scamp or elsewhere?
10-07-2014, 06:49 PM
Trailer: Scamp 13' Standard
I had same problem with water wicking up the rat fur in the door. I replaced with the d seal kit from scamp and all is well. But for me, it was quite the pita to get the foam off- didn't come off all nice and pretty for me and I tried my darnedest to get the adhesive to come off with the foam. Shucks.
Lots if goo gone, acetone at tge end, scraping with plastic putty knife, sometimes a green scrubber and elbow grease. Oh yeah used blow dryer to heat up adhesive first too. Just out it in and left cutting for the last. Didn't know about potential problems with application till just now! But application was easy and it's watertight.
Scsmp dies not show this in parts page, you have to ask for it. Think it was 18 bucks plus outrageous shipping, as is status quo.
In short, glad I did it. That foam stuff had shifted and was falling off completely near bottom if door threshold. Best wishes and good luck!
Wendy
10-07-2014, 08:21 PM
Roger,
I got mine from Scamp and it didnt cost anything. But I called Scamp as soon as I got home with it from the factory. So, they sent me the D-seal probably to shut me up. I did do as they asked and waited for the door to cure before trying to apply it.
Seriously, I encourage EVERYBODY that buys a new Scamp to ask for the D-seal. I wouldnt order it and pay for it....they have it as Wendy (CampyTime) said. But the sponge IS a pain in the royal wazoo to get off...but it's worth it. Mine was doing as she said...pushing off down on the bottom right of the door.
If someone wants to replace the sponge for the seal on an older Scamp and they're going to have to purchase it, I have the dimensions on one of the pics I show on my Flickr photos I linked earlier. I'm thinking JC Whitney may have it as well. I would try Scamp first. Doesnt hurt to shop'em.
10-08-2014, 05:03 AM
I looked all over for it and ended up buying from scamp as I couldn't quite find some in the dimensions scamp offers. Closest I found was on eBay and if I remember correctly it was too narrow. My auto mechanic tried to get from napa and couldn't locate it. It is a big royal pain to get the foam off but well worth it in my mind. Just be sure you have the radio going and plenty of beer to keep you cheerful
10-08-2014, 06:10 AM
IF, and I do mean IF, someone can find this some place other than Scamp, how many FEET should someone order?
And IF, someone does find it... please let everyone know WHERE and how much you paid. THANKS!
10-08-2014, 09:49 AM
I just called Scamp and talked with Micah Eveland (Kent's son). He said they had the D seal but it's 1/2" x 1/2" now. Mine was 1/2 x 3/4 (preferred). FWIW, I couldnt locate ANY 1/2 x 3/4 D-shaped rubber seal by searching on the web! (Amazon and Ebay produced pretty much the same results)
He said theirs shipped was 16' lg and apx $16. (+ shp of course). So, use this as a reference point. I do remember mine being apx 15' long. I had some left over.
10-08-2014, 12:13 PM
Originally Posted by Darral T.
David,
I did as well when I phoned to order it. Was told they do not recommend it as they were having problems with the adhesive on it and that it did not stay in place. Told them I would take my chances.
The funny part is that I have had the D seal on for well over a year and no movement at all - it looks great. Had replaced the stuff scamp like to use almost yearly due to how easily it tears and the amount of movement - even though I had spent hours each time cleaning up the fiberglass before putting the new stuff on to get a good bond.
10-08-2014, 12:20 PM
16' will be enough to do around the door. Might have a foot or so left over but better to have more than not enough.
10-08-2014, 12:22 PM
[QUOTE=Carol H;486417].... Was told they do not recommend it as they were having problems with the adhesive on it and that it did not stay in place. Told them I would take my chances.
Good for you Carol!! Although, that's why I prefer the 3/4" wide-- naturally, you get an extra 1/4" width to help hold the seal for the entire perimeter.
BUT--- the ONLY place I've ever have give me trouble staying on is at the bottom right hand side of the door. As I mentioned in another post, use a little light lubricant when it's new and it works FINE. And another thing, think about it; the door stays shut for the most part (at night etc.) and there's no way really for the seal to come off. I remember doing my seal, made sure the door was shut good and didnt open it for several days. Also, I think applying it in warmer weather gives a better chance for it sticking long term and helps the seal "form" or "seat" to the door. Just my opinion though.
10-08-2014, 05:51 PM
What parts (Devon) told me is that"they haven't quite found anything yet that works real good with their curved door." But after applying D, this is a whole lot better than foam!
10-08-2014, 09:51 PM
This is what I used. This type of thread has been posted many times, and places that people have been able to purchase. I did this modification long ago and don't remember a lot of particulars, but do remember that leakage was a thing of the past. This rubber seal was used both around the door opening as well as around the door.
