door lock (it wont!) - Fiberglass RV
Old 06-20-2009, 02:46 PM   #1
Trailer: 1976 Boler 13 ft
I have door sag so my door doesn't fit properly and therefor doesn't lock properly. a previous owner(s?) has cut away part of the locking system and then beefed up the bolt portion with screws to compensate for the cut away metal. (this may have been 2 separate people failing to solve the problem on 2 separate occasions) Anyway. i have had help with the door, and the bolts and pins were replaced with new but the sag only went away briefly. It is better than before though. Has anyone had any success with a new lock, or fixing the old one? i am worried about security b/c i travel alone sometimes. I've also been advised not to put an outside lock on in case some joker locks me in. i could just add in a basic lock set for inside safety, but ideally i would like to see what can be done with the original lock or location of lock before i have to start messing it up with screwing a new extra lock into the door and frame. thanks for the tips
cyndi H is offline   Reply With Quote
Old 06-20-2009, 10:12 PM   #2
Roy in TO's Avatar
A picture is worth a thousand words
Old 06-21-2009, 10:37 AM   #3
Trailer: 1991 17 ft Horizon
Roy is right a picture would really help. But it sounds like you should fix the door sag first, then turn to the lock. Some have fixed the door sag on Scamps, Bolers etc. with a couple pieces of angle iron and a couple pieces of all thread. Maybe Donna remembers who had some pics of their mod, if not I'll look around in my computer for them. After thinking about this the mod I'm thinking about is the curve on the bottom of the door mod, so I don't think that is going to help you with a door sag. I'm sure someone here has fixed a door sag on a Boler though.
Old 06-21-2009, 10:48 AM   #4
Con created an in depth article about fixing an aircraft-style door. Some or all of the ideas may be used. But I agree, trying to fix the lock without fixing the door maybe merely a bandaid solution.
Boler Door Fix Document
Old 06-22-2009, 01:17 PM   #5
ok, thanks. i will take some pics today and post later. i'll have to review that door fix document as well. (i really really really wanted to avoid that) i've already dealt with the door with no permanat success. Dealing with the door feels like looking up at everest. Oh well, that is life. I will look at it, thanks a lot. I'm still hoping someone has had experience with a good bandaid though.
Old 06-22-2009, 01:23 PM   #6
band aid all the way!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! there's no way possible that door will be fixed like that. No way ever do i have time, energy or tools for that. I`ll post pics later and ask for band aid examples and suggestions.
Door Lock Errol Holbrooke Problem Solving | Owners Helping Owners 44 12-26-2011 09:25 PM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
Door Lock Paul Richter Problem Solving | Owners Helping Owners 0 05-18-2010 10:30 AM
I'd like to add a sliding door lock Russell, H Problem Solving | Owners Helping Owners 12 10-07-2009 04:18 PM
Dometic 211 Door lock kylieh Problem Solving | Owners Helping Owners 6 10-09-2007 06:47 PM
