Door locks - Fiberglass RV
Old 11-20-2005, 06:31 PM   #1
Trailer: Scamp 13 ft
Post
Hi, I am new to this list and I have only had my Scamp for about 2 weeks. The outside door latch is missing. I have a replacement but the screw holes are covered by the latch plate on the inside of the door. How or what can I do to fix this? Any ideas?
Thanks,
Lee
Rev. Lee Cook is offline   Reply With Quote
Old 11-20-2005, 11:36 PM   #2
Pete Dumbleton's Avatar
Lee, it's been a while since I turned my outside handle upside down (so bears, dogs and 'coons couldn't lean on it to open it), but I believe all you have to do is unscrew the six wood screws holding the inside mechanism to the door.
Old 11-21-2005, 10:41 PM   #3
Thanks for the reply. I took the inside latch off the door and trier to attach the out sidde latch but the screw come through to far to reapply the inside latch? So, untill I can find a way to fix it, I am not able to lock it.
thanks,
Lee
Old 11-21-2005, 10:58 PM   #4
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
I found this. I’m not sure if it helps or not.
Lock Replacement
Old 11-22-2005, 08:42 AM   #5
Dan Meyer's Avatar
I'm also having trouble with my door latch, and attempted to remove the outside handle last weekend. I found the outside handle is attached with fairly short wood screws. You may need to grind off the end of the screws you are using, or simply use shorter screws to attach the outside handle to the door.
(I was not successful in removing the outside handle, but that's another story...)
-- Dan Meyer
Old 11-22-2005, 08:14 PM   #6
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
-- Dan Meyer
Ok Dan... c'mon... give it up! I sense a good story here!
Roger
Old 11-24-2005, 11:14 AM   #7
Dan Meyer's Avatar
Roger Said
"Ok Dan... c'mon... give it up! I sense a good story here!"
It's not much of a story.
The door handle on our Scamp is sticky. When opening the door, the handle will stick in the down position, and is difficult to move. I figured it would be simple to repair; just remove the handle and latch assembly, clean everyting up and put it back together.
I removed the screws holding the outside handle to the trailer, and pulled. Hard. Then I beat on the stem from the inside. It didn't budge, and I gave up.
I'm applying penatrating oil every day or two, and will try again one of these days. If it still does not budge, I'll get out my drill.
-- Dan Meyer
Old 04-17-2006, 08:12 PM   #8
Dan Meyer's Avatar
I got out my drill. Drilled a 1/8 inch pilot hole, then a 1/4 inch hole about 5/8 inch deep into the square shaft. Then I hit it with a punch in the center of the hole I drilled. The handle finally came out!
I am now looking for a different type of latch to replace the stock latch because I don't like having to turn the handle by hand while closing the door. Anyone have any ideas?
-- Dan Meyer
Those 'elusive' Bargman 400 locks Doug Mager Parts: Buy | Sell | Trade 27 10-15-2013 06:38 PM
Trailer Wheel Locks/boot Rich S Problem Solving | Owners Helping Owners 0 07-26-2009 10:08 PM
Trailer Wheel Locks E. Graham Towing, Hitching, Axles and Running Gear 5 08-13-2007 01:16 PM
Hitch locks Yves Pelchat Towing, Hitching, Axles and Running Gear 15 02-07-2006 03:58 PM
Trailer Wheel Locks/boot Rich S General Chat 0 12-31-1969 07:00 PM
