door on `98 scamp won't seal - Fiberglass RV
Old 07-07-2013, 01:02 PM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
After I finished washing the outside of our Scamp I noticed water on the floor. Lookin at then top of the door I can see that it's not making much of a seal with the foam gasket. It looks like the door has "flattened" out a bit.
I was wondering if a ratchetting cargo strap could be used to pop it back into shape.
fusedlight is offline   Reply With Quote
Old 07-07-2013, 01:36 PM   #2
Roy in TO's Avatar
More likely the body had bulged a bit. Gives a similar appearance.
Old 07-08-2013, 08:22 AM   #3
fusedlight's Avatar
Roy... that may be so, but the effect is the same. Original question... can I "add" some curve to the door with blowing it up?
Old 07-08-2013, 06:35 PM   #4
In one word.. No. And you can't "pop" it back in shape by using a ratchetting cargo strap unless you plan on leaving it in place... sorta like using wire and turn buckles.
It's work, but there are solutions. Here's one: Fiberglass RV - Document Center - Exterior Check out Robert Johan's excellent rightup for a Scamp door repair.
Old 07-09-2013, 08:53 AM   #5
fusedlight's Avatar
Thanks, Donna. Looking at the PDF, a strap DOES work, so long as you are using it in conjunction with physical alternations to the door. Oh Well...
This time tomorrow, we're ON THE ROAD for North Carolina! Woot!
GcB
Old 07-09-2013, 09:13 AM   #6
GMike A's Avatar
Here was another solution that I dont think anyone would want more than a stop gap measure. IMO
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-09-2013, 09:51 AM   #7
fusedlight's Avatar
That's actually kind of an elegant solution. If the connection points at the top and bottom are mounted correctly, the door won't fracture around the connection points. If done correctly with bright-finish stainless, this could be quite nice and a lot easier than cutting apart the door.
BTW... do you have a link to a discussion of this method?
Old 07-09-2013, 11:14 AM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
The picture is from post number 13 at the following very interesting thread:
Lots of Scamp modifications
Francesca
Old 07-09-2013, 12:09 PM   #9
GMike A's Avatar
Thanks FK. I saved and printed the section out to PDF as indicated it was resurrected at one time and was a posted again. Some of these are ancient by today's forum standards.
Restoring Our 1972 Boler American
Improving door fit due to body sag
Mike
K5NAN
"Miss Adventures"
Old 07-09-2013, 07:04 PM   #10
Mike posted a picture of the wire and turnbuckles I mentioned in my post #4. Another solution has been to create a wood rack of sorts (shoes, magazines) that is to the shape you WANT the door to hold, then bolt it through the fiberglass, which effectively pulls the door back into shape.
I'd just get thicker gasket material (at least for a while)
Old 07-09-2013, 07:16 PM   #11
fusedlight's Avatar
I just got a note from the builder of the turnbuckle door. It's doing just fine! He gives it a cinch every so often. Sounds like a plan!
Old 07-15-2013, 08:06 AM   #12
Trailer: scamp 13'
valdivia, Chile
Hi! This seems like a great fix GMike A!! Any chance that we could get a close up to see how you attach it to the door? Do you screw it through the door? of rivets will do? Thanks!!! I have major headaches with this door!!!
greetings from Chile.
horito is offline   Reply With Quote
Old 07-15-2013, 08:33 AM   #13
GMike A's Avatar
Thanks Horacio. I did not do the modification myself. If you see the answer above me by Fusedlight he talked to the person who did it. I am sure Gary will read this soon and he can help you contact the original person. I am curious also as I have the same issue on my door.
Nice to see the Scamp is everywhere.
Mike
Mike
K5NAN
"Miss Adventures"
Scamp/Hehr door window won't drain? dylanear Problem Solving | Owners Helping Owners 7 04-05-2013 12:56 PM
Scamp Door Seal Parker Buckley Problem Solving | Owners Helping Owners 16 10-11-2011 09:55 AM
Help...Door won't open! gacole2000 Problem Solving | Owners Helping Owners 8 08-25-2011 09:16 AM
Door won't seal. carole sullivan Problem Solving | Owners Helping Owners 14 06-21-2007 12:02 AM
