Door on my 2004 scamp 5ver? - Fiberglass RV
Old 09-17-2014, 07:56 PM   #1
I love my 5th wheel Scamp........but the door drives me nuts! It is too tight at the bottom hinge side when closing and can't find a seal that will last a half of season. It came with that factory assist strap that scamp sells for doors that are too tight. I have to reach down and pull the door out when closing to avoid "wiping" the seal away. Anyone have this problem and came up with a better solution?
John
gihuff is offline   Reply With Quote
Old 09-17-2014, 08:26 PM   #2
IllAnnoy
A "D" shaped closed cell door gasket is now available directly from Scamp.
Old 10-03-2014, 06:07 AM   #3
Trailer: Tote n tarry
Mississippi
What is it called exactly? I do not know what I m looking for on their site
Melissa in Memphis is offline   Reply With Quote
Old 10-03-2014, 06:47 AM   #4
Trailer: 2014 Escape 21
Virginia
Melissa
The thick D seal is available from Scamp but you need to call the parts department.
John
Sounds like your door too tight against the trailer. I would shim out the lower door hinge on the trailer side. I have made metal shims out of aluminum sheeting. Also put butyl tape under the hinge when reinstalling to prevent leaks from under the hinge.
Eddie
Old 10-03-2014, 06:49 AM   #5
Mississippi
Thanks for the help. I am in contact with scamp now
Old 10-03-2014, 06:54 PM   #6
Anyone ever have a leak on through the hinges on the 5th wheel model? I have a deluxe that when we had a good rain, the hamper floor carpet would be wet as well as the first step (which are the same level) goin up to loft.I figured awning attachment, nope, not the running light, hinges possibly, don't think the belly band is an issue.
Old 10-03-2014, 07:14 PM   #7
Virginia
John
Check your hinge bolts on the inside if they are rusty you have a leak. Scamp does not seal under the hinges or at least on the trailers I have seen. Just take your door off with the ball bolts. Remove the castle nuts and hinge brackets on the trailer side and put butyl tape behind the brackets. I usually replace the hinge hardware with stainless hardware. While working in that area I replace the door hold back bracket with a stainless bracket.
The answer to your question is water will leak into the trailer through the hinge mounting bolt holes.
Eddie
Door Hinges and Scamp Door sill Cat futrell Problem Solving | Owners Helping Owners 4 10-15-2012 07:46 PM
Nice 2002 Deluxe 5ver for sale - ready for your solar panel grace Referrals: Molded Fiberglass Trailers 0 05-24-2012 05:05 PM
2004 Trillium Door Lock theresa p Problem Solving | Owners Helping Owners 13 11-29-2010 06:00 PM
2004 Scamp Trailer - 16ft Kevin K Classified Archives 0 07-15-2009 05:35 AM
13' 2004 Scamp Dana T Classified Archives 1 06-15-2009 09:35 PM
