door on scamp 5th wheel - Fiberglass RV
Old 07-23-2013, 08:21 PM   #1
I have a different door issue than most I guess. My door is tight at the bottom to where scamp has put a metal bar at the bottom hinge side to guide the door shut. When closing, the bar pushes the door out to clear the pinch weld, Very hard to keep a seal in place there. The real problem issue is this:
When the door is latched, there is a gap in the seal at the latch area.
It appears that the body is sucked in from about 9" above and 9" below
the latch. Lookin down the side of the trailer with the door open you can see this also. You can see the belly band actually not in line with the belly band on the other side of the door.I thought if I could wedge something in between the skin and the oak vertical support inside the door, I could push this out to even up the door opening but I don't see how the skin is attach to anything. No screws etc. Anyone know what holds the skin at this area or what its attached to?
gihuff is offline   Reply With Quote
MI: Scamp 5th Wheel Thomas G. Referrals: Molded Fiberglass Trailers 0 05-29-2013 08:35 AM
Scamp 5th wheel. jbates52 Hi, I am.... 4 11-23-2012 04:49 PM
83 5th wheel Scamp Darrin S Referrals: Molded Fiberglass Trailers 1 05-24-2012 08:37 AM
Scamp 5th wheel or Escape 5.0 or other small 5th? Linda Gaudet Wanted: Molded Fiberglass Travel Trailers 16 04-27-2012 09:21 PM
Looking for a Scamp 5th wheel Opal Wanted: Molded Fiberglass Travel Trailers 11 07-09-2007 10:28 AM
