Door sagging? - Fiberglass RV
Old 11-21-2008, 04:40 PM   #1
Trailer: 1960 28 ft Airstream
What is causing my door to literally be unopenable by the time I finish towing to my destination? It acts like it is sagging, and jamming, my son had to climb thru a window to open the door. It also acts like the lock is jamming, but it is really the door. There doesn't appear to be any broken hinges or cracking. Any ideas?
Pam
Pamela H is offline   Reply With Quote
Old 11-21-2008, 06:05 PM   #2
It's obviously binding. Did you make sure the trailer was level before you tried to open it? My 1988 gives me grief every once in a while, if it's hooked to the tug and one wheel on the trailer is lower than the other. I don't have problems once it's unhooked and level, however. Others may have a different idea.
Old 11-26-2008, 10:48 AM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Pam
Have you (or previous owners) done any 'customizing' to the inside, like removal of any body parts? Most of the innerds of these eggs are actually for support to help keep the shells from imploding on themselves. If there were some of this work done, (parts removable) it 'might' have weakened the shell enough to give that collapsed effect. The frame also MIGHT be cracked which, once the trailer is leveled, might make this problem go away, but come back after being in transit...
Old 11-26-2008, 10:55 AM   #4
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
My guess a crack in the frame.
Old 11-26-2008, 04:15 PM   #5
No modifications to the inside...esp as the burro has molded pieces to the shell, as opposed to removable. Where would I look for frame cracking?
Pam
Old 11-26-2008, 10:16 PM   #6
Doug Mager's Avatar
I'm not at all familiar with the frame on your make of trailer, the weak spot on Trilliums seems to be at the front where the frame takes a nosedive under the front of the glass shell, ....MAYBE start looking there???
Old 11-28-2008, 03:03 PM   #7
pjanits's Avatar
Trailer: 17 ft 1986 Burro
Wait for a fairly warmer day, crawl under the trailer with a really strong light and examine every square inch of the frame.
If there are any cracks you'll see them with a strong light.
If found , find a welder that can patch them up.
If you don't see any try again next year.
My Burro had failed at the "A" area on both side sometime in its past and was repaired, the repair is better than the rest of the frame.
No More Sagging Drawers Dave Bese Modifications, Alterations and Updates 8 05-17-2010 01:23 PM
Sagging doors Rick kl Problem Solving | Owners Helping Owners 11 12-01-2008 05:13 PM
Sagging roof..... kentj Problem Solving | Owners Helping Owners 2 08-29-2007 09:52 PM
Sagging Trillium Door Fix Joseph Olajos Problem Solving | Owners Helping Owners 4 07-12-2007 02:36 PM
sagging door Legacy Posts Problem Solving | Owners Helping Owners 29 07-08-2003 10:39 PM
