Door squeak......solutions???? - Fiberglass RV
Old 09-05-2014, 09:34 AM   #1
this might seem like a small irritant...but as many such things the longer it goes on the more it gets on your nerves.....door squeak !!!
I've poured oil, I've sprayed white grease.....in LARGE quantities on my main door hinges and STILL and they still squeak....driving me nuts!....
Has anybody "been there, done that"....and what exactly was the "done" part...cause I can't seem to find it.....TIA.....trailer is a B17CB....1997 BTW
Old 09-05-2014, 11:06 AM   #2
Would appear that the oil is not getting between the spaces of the hinge. Try some PT Blaster as it has a foaming action and penetrates.
Old 09-05-2014, 12:04 PM   #3
yeah, that's the cause....
the hinge is a series of hinges and in between them there are nylon bushings it looks like....they are probably so tight to the shaft that the oil/grease is no getting to where it need to go.......
I'm toying with the idea of drilling a small hole at the top of each hinge to be able to put the tube from an aerosol lube can right up against the shaft
was just wondering if somebody had some success with other (easier) fixes
Old 09-05-2014, 02:36 PM   #4
CampyTime's Avatar
Trailer: Scamp 13' Standard
I replaced the hinges on my scamp with new due to squeak. No luck. This summer while camping I sprayed the bushing and spring/bolt assembly with silicone spray about once every 3 weeks or so. It worked for that time only, then the squeak would come back, but only on my Lower hinge. I resigned to that's the way it is because with new hinges and still a squeak, what else is there to do?
Old 09-05-2014, 03:36 PM   #5
If you follow the lead of others, when the furnace doesn't work, you remove it. When the fridge doesn't work, you remove it. Hinges squeak ...<_<
Old 09-05-2014, 06:02 PM   #6
papa-t's Avatar
Glade Valley, North Carolina
I have a rattle noise n my 2012 Chevrolet Colorado somewhere near the dash on the passenger side. Drives my crazy. My wife thinks I'm nuts. I know your pain.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 09-05-2014, 07:26 PM   #7
One person of my acquaintance swears by automatic transmission oil for such things as squeaky Scamp hinges. Now for big foot, different animal.
Old 09-05-2014, 07:53 PM   #8
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
ATF thinned with kero or paint thinner makes a great penetrating oil. Add anhydrous lanolin and you have a good gun cleaner and rust preventative. Should work fine as a squeak stopper for hinge pins and leaves where a spray lithium grease is unlikely to ever go. Jack
'99 BURRO 16WB "el Gordito"
'09 GX470 4.7L v8 them J120s
Old 09-07-2014, 01:17 PM   #9
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
I've used something called Tri-Flow on my hinges. I think It is a combination of penetrating oil and Teflon. I've seen it at a number of places, but I got my last can at a local Nuts & Bolts hardware store. Not necessarily cheap, but one or two applications seemed to do the job. I guess it carries deep into the mechanism and deposits enough Teflon to last for a while.
Good luck!
Ray
rdickens is offline   Reply With Quote
Old 09-07-2014, 05:38 PM   #10
The only times the hinges squeak on my Scamp, is if it's not perfectly level. YMMV
AND, there's no FRAME problem.
Old 10-06-2014, 07:49 PM   #11
CampyTime's Avatar
Thanks everyone. I'm going to try that tri flow stuff as the silicone just wears off too quickly. But the scamper is going away for inside storage next week so tri flow will be ordered awaiting a spring trial!
Old 11-09-2014, 06:01 PM   #12
Handley Jackson
I took my hinges apart and coated the
little brass balls and the bolts with
molybdenum grease and put it back
together. Then I wiped as much grease
off as I could get to.
Now it is silent. I don't know how long
it will last.
Handley Jackson is offline   Reply With Quote
Old 11-09-2014, 06:12 PM   #13
Ian G.'s Avatar
Is this a Scamp 13'?
How tight did you tighten the bolt with the spring?
There has to be some movement as the door opens and closes, if it is too tight is will squeak.
Should look similar to this when assembled
Old 11-10-2014, 08:48 AM   #14
Handley Jackson
I just brought the nut up to the spring. No pressure
but no slack. The first time I had a problem, I dosed
it with a little 3 in 1 oil. That made the squeak go
away but the oil washed out of the hinge and ran all
over the door. The grease it not quite so mobile as
the oil. On the other hand I have not driven the
Scamp anywhere yet either.
bigfoot
Pilot light blowing out: Solutions? J Martin Problem Solving | Owners Helping Owners 5 06-04-2012 06:22 PM
2 simple problems with likely simple solutions Earl E. November General Chat 5 10-27-2011 08:14 PM
Temporary City Storage Solutions? jbull Camping, Campout Reports 5 05-28-2008 08:33 PM
Poll of your best FAQs-solutions Suzanne P. Problem Solving | Owners Helping Owners 11 07-04-2007 03:57 PM
Bed, window and cabinet lining solutions Legacy Posts Problem Solving | Owners Helping Owners 25 05-12-2003 07:44 PM
» Trailer Showcase
Light House
Lora
Boler
Borden
