Doorway Floor Issue.. - Fiberglass RV
Old 06-30-2013, 01:26 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
I noticed when I step into the Scamp the floor drops/separates from the wall about a 1/4 inch. Is this a frame issue?
Maybe it's my weight issue
barryra is offline   Reply With Quote
Old 06-30-2013, 01:47 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I don't have a Scamp, but from what I understand about their construction, the floor consists of OSB connected to the fiberglass sidewalls at the edges. I think that there are a few inches between sidewall and frame.
It seems more likely to me that the wood floor may have separated just at the sidewall, perhaps due to water intrusion?
Crawling under the trailer and taking a look sounds in order...
Francesca
Old 06-30-2013, 04:43 PM   #3
barryra's Avatar
Francesca
Hey.. Thanks Francesca
Old 06-30-2013, 04:55 PM   #4
You're welcome...
And FYI- there's a pretty good description of Scamp floor attachment method, with pics, at this link.
Good luck!
Francesca
Old 06-30-2013, 05:47 PM   #5
Trailer: 2014 Escape 21
Virginia
Barry
On some of the older Scamps there is no support under the floor at the doorway. The floor spans between two metal brackets that extend from the frame to the lower door opening. These two metal brackets have lips on them to catch the floor. At the edge there is a U shaped threshold to help support the outer edge of the floor.
Just yesterday I noticed on a 2005 S-13, it looks like they added a piece of 1" or 1.5" angle Iron to help support the floor at the door which spans the between the metal walkway brackets. Check to see if yours has this bracket, if not there it is not hard to add the angle support.
Eddie
Old 06-30-2013, 06:09 PM   #6
Virginia
Picture of frame and doorway support. The picture came from this site. I have seen some older trailers without the outer angle iron support. Check for rust or bad welds in that area.
Eddie
Old 07-01-2013, 02:19 PM   #7
barryra's Avatar
Thanks Eddie! That's a huge relief on my mind.. I was picturing I needed to take the body off the frame & re-do everything. I think I'm going to bring it by a local weld shop & have the put in a support.
Old 07-01-2013, 06:34 PM   #8
Barry, just make sure they know how to weld around fiberglassRV... including the resin coated floor. I know of TWO trailers that were lost to fires from welding...
Scamp, distance from ground to doorway monB General Chat 4 04-26-2012 12:20 PM
"Between every two pines is a doorway to a new world." John Muir Adrian W General Chat 3 05-15-2011 03:01 PM
A/C Issue Georgana D Care and Feeding of Molded Fiberglass Trailers 8 07-28-2010 12:09 AM
overcoming a "charm-ectomy", rotten floor & other issue Kelly G Problem Solving | Owners Helping Owners 5 05-22-2009 12:57 PM
Uhaul doorway threshold? Jamey Problem Solving | Owners Helping Owners 7 02-10-2007 08:41 PM
