Drained tanks and tried to blow out water lines - Page 2 - Fiberglass RV
Old 11-12-2015, 11:53 AM   #15
J.F.Y.'s Avatar
Bryan......
Gordon's observation that one can camp in a pink-stuff winterized trailer is right on the mark. I've done it once in a while.
The potential consequences of having a pump or valve or line freeze are just so time-consuming and potentially expensive that there really isn't much of a rational excuse for not having that bypass valve installed and protecting the system.
And as far as running an electric heater for the season, and that associated expense and bother...... Really? And what does the economic comparison with the pink stuff (Wal-Mart's works fine) tell you? Seriously......
Frank
J.F.Y. is offline   Reply With Quote
Old 11-12-2015, 12:49 PM   #16
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
Not sure about the Scamp or others, (or even other models of Casita) but my 2001 Casita 17SD has an inline water filter/strainer (factory I think?) between the fresh water tank & the pump (also has the hot water bypass system 'downstream' of the pump). When we bought the trailer last January (from owners in Ft Worth, TX) it had been winterized by blowing out the lines (I've been successfully doing this for many years with a number of different 'stick'built' trailers & cabover truck campers). I didn't know about the filter/strainer in the Casita & we had several 'days-long' periods of teen/low-20s temps here in central Arkansas, & last spring when I filled my fresh water tank to sanitize the system, the filter/strainer (plastic) had developed severe cracks around the top of the unit & when I turned on the pump I 'flooded' my trailer(actually I don't think the pump had much to do with it, just gravity flow from the full tank to the filter). Took 3 days of using my wet-or-dry shop vac & fans to dry it out, after I replaced the filter/strainer. Apparently the pump suffered no ill effects from the freeze(s). This year I'm blowing out all the lines but I'm also adding enough of the pink RV anti freeze to fill both the filter/strainer & the pump, as well as all P-traps & the toilet valve. Since I sanitize the system each spring it'll be no problem to 'flush' out the pink stuff. As for using pressure to 'blow out' the system, I've always just used a homemade (6 inches of the 'male' end of a garden hose with a tire valve stem clamped into the hose end) adapter screwed into the 'city' water inlet, & my shop compressor with longer air hoses and an air chuck to blow the lines/faucets. Longer air hoses are much better than long extension cords as there's no 'line loss' of voltage/current. Never had any damage to my RV water systems as long as I open the faucets. I still leave the RVs plugged in (usually parked under a shed) with a small 'cube' electric heater set on low/very low. That shed/storage area is on a separate meter with a minimum monthly charge of $13, & I don't remember more than a time or two having to pay an extra charge, & then only a dollar or so. I suppose if you're on a regular 'metered' line, an extra $10-$13 might be of consequence but I'd consider it well worth it to prevent damage to water systems...
Harvey is offline   Reply With Quote
Old 11-12-2015, 03:32 PM   #17
about running heaters.....
it's more than just heat..it's ventilation...
i'm not sure what would be worse...looking at frozen pipe damage in the spring...or mold and mildew to clean up in a lot of places...some very difficult to access
happened to me ONCE....never again....I always run a heater....right now I have one that has a "45" setting.....won't let the temperature drop below that....and when it comes on it moves the air around...I like that
might not be a problem in a "dry" place...but it's "moist" where I live
Old 11-12-2015, 04:07 PM   #18
Roger C H's Avatar
Smile Thanks Gordon & Wayne
I had already forgotten from the one time I used RV anti-freeze about those instructions to not dilute.
Goes to show you that we are all smarter together than individually.
I poured a gallon of pink anti-freeze into my system after draining it as much as I could, then drained the pink stuff after.
I only use a small plunger to clear out the sink to gray water bucket now since we no longer use the plumbing.
Old 11-12-2015, 05:23 PM   #19
Ventilation is a BIG issue. A trailer that you are able to leave a window or a vent open all winter on is always going to fair better than one that is closed up tight.
Old 11-12-2015, 06:00 PM   #20
Trailer: Escape
So far, everyone who heats uses an electric heater. Why not run a propane heater? If propane is priced like gas, then propane should be less expensive than electric to heat. I know it might be more convenient to have the fuel flow through a wire rather than from a tank you have to refill, but are there any other advantages I am not seeing?
Bill Dornbush
http://dornbush.net
hwdornbush is offline   Reply With Quote
Old 11-12-2015, 06:36 PM   #21
Myron Leski's Avatar
Trailer: 19' Escape
NM
Bypassing the water heater to run the pink stuff...
Myron Leski is offline   Reply With Quote
Old 11-12-2015, 08:26 PM   #22
I suspect most folks including myself would be very reluctant to leave any gas appliance burning in an unattended trailer...... not to mention the need to do a number of trips to have the tanks refilled over the course of a winter and also need to have the trailer plugged in to maintain the battery - propane furnaces are power eaters.
Old 11-13-2015, 12:42 AM   #23
Borrego Dave's Avatar
Trailer: Casita SD17 2006
MMMM, running a LP heater for the winter while stored? If something should happen with an electric cube heater the fused line will shut it down. LP heater.....first guess would be a pile of molten FG. Would you walk away from your kitchen stove while you're cooking dinner on it for a few months?
Old 11-13-2015, 02:50 AM   #24
Trailer: G30 Elite Class C
water tank and electric pump
Originally Posted by HAPPYSCAMPER76 View Post
It snowed a bit here at our house here in California, so I figured I better winterize the new to us Scamp trailer. I would have done it sooner, but had to fix a leaky bathroom faucet before being able to blow out the lines or put antifreeze through the water system.
So I drained the fresh water tank, bought a 1 and 1/16 long socket and pulled the anode plug. I also bought a little doohickey to help flush out all the deposits, which there were lots. I ran the water pump until there was not any more water coming out of the pump. I installed a new anode plug. I also bought a brass fitting with a presto valve to put into the outside water source fitting. I then turned my compressor down to 30 psi on the outlet side, had the wife go in the trailer and turn on the faucets one at time while I compressed air into the special fitting doohickey. She said some water came out of each faucet, but there is still a bit of water in the lines. I could here gurgling over by the outside of the hot water heater. She could also here gurgling coming out of the faucet (I could also see the water and the air bubbles in the hoses below the bathroom sink). I tried for several minutes to get the water out of the hoses, but nothing more came through the faucets. I turned the compressor to 60 even just to see, but it did not help, and I know 60 is probably too much pressure anyway. I also turned the water pump on again and it pumped more water out. I then tried to compress air into the system one more time just to see but nothing happened. I finally pulled the hot water heater plug again, but no more water came out of it either.
My question is how can I get all the water out of the lines? I would just run antifreeze through the system at this point, but the aftermarket Suburban hot water heater does not have a bypass valve (I did buy one today, but have not installed it and deep down don't really want to put antifreeze in the system anyway, especially because we are camping for a week in about 9 days). A few things I noticed were, that the brass fitting with the presto valve seemed a bit funky. I had to press inward really hard on it to hear the gurgling or to see air bubbles coming out of the brass fitting. It appears that you would have to get the one way valve in the fresh water inlet lined up just perfect for the air device to push in on it and allow air into the trailer water hoses, etc. I messed around with the hotwater pressure valve to make sure that was not leaking air, but nothing happened after that either.
Does anyone have any thoughts on the matter? Do I have to get all the water out of the hoses? I would think it would give me more security to do so. Do you think I have a new leak somewhere? There was a bit of air coming out the brass fitting and the fitting to hook in the water? I had the fresh water tank drain plug closed. What am I doing wrong?
: we had a situation where we had just filled the water tank and low and behold the pump quit with about 55 gallons of water on board. it takes forever to drain the tank so when we got to the RV place we waited nother 2 hours for it to drain then we installed shut offs on either side either side of the Pump so next time we can isolate it and not have to drain good drinking water off, as the water we got in Maine was not all the good for drinking so had to buy bottled water.
Stude
stude is offline   Reply With Quote
Old 11-15-2015, 05:01 PM   #25
Trailer: Currently Shopping
What type of electric heater do you folks that leave it running all winter use?
margvv is offline   Reply With Quote
Old 11-15-2015, 06:58 PM   #26
electric heater
Marg, we use a heater that can run 500W, 750W, or 1500W, we leave it on the 500W and if it gets real cold like -10 or lower we turn it up to 750W as it just keeps the damp weather out of the interior of the MH we lift up the bed which opens up the water tank area which is 98% empty, lots of room for expansion, we open up all the cupboards, fridge/freezer doors, leave the table benches closed as they are vented and heat can get into those areas. Just keeps it warm in case we need to use it for a few days.
Were both pensioners but look at it this way cheaper to keep the heat in than do major repairs in the spring.
Stude.
Old 11-17-2015, 08:20 AM   #27
David and Nancy's Avatar
Trailer: Bigfoot 25 ft (25B25RQ)
Blowing out the lines AND running pink anti-freeze is a waste of time and effort. Once you add anti-freeze into the water system, you simply run each tap until clear water is replaced by anti-freeze. Having a by-pass on the water heater is essential or the drained water heater will want to fill up with the anti-freeze - usually about 6 gallons. The 12V water pump on my trailer has a winterizing hose attachment that will go directly into a bottle of anti-freeze. It takes less than 2 gallons to do all the water lines, then I manually add some to the P-traps in the sinks and shower drain. It is so cheap and easy that I don't mind de-winterizing and re-winterizing as necessary late in the season. If your trailer does not have the anti-freeze attachment on the pump, you can pour anti-freeze into the fresh water tank and pump from there. Still easy, but will require flushing that tank to de-winterize.
Using compressed air alone is a riskier way of doing it. There is no way to know what pockets of water may be missed and do damage during the next polar vortex. Where we live we can depend on it reaching 20 below occasionally every winter.
David and Nancy is offline   Reply With Quote
Old 12-11-2015, 02:38 AM   #28
Trailer: currently shopping
Manitoba
lawkmlaw is offline   Reply With Quote
Camco RV Blow Out Plug CampyTime Care and Feeding of Molded Fiberglass Trailers 27 09-11-2015 02:26 PM
Blow out on the freeway MCDenny Towing, Hitching, Axles and Running Gear 114 01-09-2015 01:49 PM
A Better DIY Adapter to Blow-out Water Lines Ian G. Care and Feeding of Molded Fiberglass Trailers 6 11-03-2014 01:26 PM
Battery drained??? Flygal Problem Solving | Owners Helping Owners 4 01-28-2010 06:49 AM
HOW do you blow out your trailer water lines? Karalyn Plumbing | Systems and Fixtures 8 10-16-2006 07:18 PM
