Drawers in closet - Fiberglass RV
Old 02-08-2015, 06:15 PM   #1
courtney's Avatar
Trailer: 1982 13ft Scamp purchased on May 2nd
Drawers in closet
I've seen various pics online of different types of drawer units installed in the closets of eggs. My question is, how are they secured in the closet?
courtney is offline   Reply With Quote
Old 02-09-2015, 09:26 AM   #2
global2edg's Avatar
Trailer: 2015 Casita SD 17
Shelves may be a better way to go, or at least very open drawers. I have found that the closet works best when there is air flow. Especially true when in colder climes. Or be willing to take closet door off. Closet stays cold, and can have condensation issues if you're not careful.
global2edg is offline   Reply With Quote
Old 02-09-2015, 10:17 AM   #3
Trailer: 1978 Trillium 4500
The previous owners of our trailer put in adjustable shelf brackets. They are bolted through the frame of the closet.
Island Claire is offline   Reply With Quote
Old 02-09-2015, 01:46 PM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
All the egg brands I know of have a 1/2 inch plywood floor under everything in the trailer. Many use this as the base to attach a framework for shelving, while other attach drawers to the those shelves.
I've seen a couple nice frames built out of PVC piping with shelves screwed to them.
Other anchor points are the closet door framing, and the wooden closet rod.
Charlie Y
Charlie Y
Old 02-09-2015, 04:20 PM   #5
Drawers in closet
Here's my solution, and it cost $15 and less than 30 minutes to install:
Name:	Closet Mod 5.jpg
The bins came from Big Lots, cost $3.50 each, latch together for stability, and fit my Scamp closet perfectly. The bottom bin rests on an old plastic crate that I inverted and notched to fit over the wheel well. The whole stack fits so snugly that no permanent attachment is needed, but I used one tension curtain rod to hold the bottom bin snugly against the front of the cabinet since the closet is about an inch deeper there.
They have worked really well. Nothing falls out and everything is visible and easily accessible. They probably wouldn't work for heavy items, like canned goods, but I prefer to store heavy stuff low and forward (under the front sofa).
Old 02-09-2015, 08:46 PM   #6
I had a bunch of "Closet Maid" stuff left over in my garage and used the wire shelving in my Scamp. Flipped the shelves over (lip up) so stuff doesn't slide out and hit the closet door while under tow.
In a tiny trailer, who really needs a "closet"? It's not like I need to hang up a prom dress. YMMV
Old 02-13-2015, 06:40 PM   #7
Trailer: 76 Honey Neonex Boler
Saskatchewan
I have shelves that are secure to the inside of the closet by strips of wood epoxied to the fibreglass. I also have a shelf/drawer on sliders that are attached to a strip of wood. The wood strip is glued to the fibreglass with PL Premium construction adhesive.
Karen L W is offline   Reply With Quote
Old 02-18-2015, 09:23 AM   #8
courtney's Avatar
Thanks for the ideas, folks! I bought some of the "buckets" from Ikea that act as sliding drawers. We'll build up a frame around it. Will put some pics up when done.
Old 02-19-2015, 07:28 AM   #9
Courtney, I vaguely recall someone here posted a closet mod using those same IKEA bins. I assume you're talking about the plastic ones that slide on metal C-channel.
I notice you're using the app, but if you go on the website and do a Google site search for "IKEA" and the exact name of the bins, you might turn it up.
Old 02-27-2015, 05:38 PM   #10
julmar's Avatar
Trailer: 2017 Escape 17B
Idaho
Thanks Jon for the big lots bin idea. I just did this & it will be great storage for light items.
julmar is offline   Reply With Quote
Old 03-03-2015, 07:07 AM   #11
courtney's Avatar
Well, the IKEA bins are just a tad to wide to hit in my closet :-/
Going for wire baskets instead.
Shelves and drawers in Uhaul CT13 closet Bridget T Modifications, Alterations and Updates 4 08-06-2010 05:21 PM
scamp 16 drawers Legacy Posts Modifications, Alterations and Updates 14 07-23-2003 08:01 PM
Cargo drawers Legacy Posts Modifications, Alterations and Updates 16 10-09-2002 06:34 AM
Cargo drawers General Chat 0 12-31-1969 07:00 PM
Cargo Drawers General Chat 0 12-31-1969 07:00 PM
