Drill bit walking on Rivets - Fiberglass RV
Old 10-09-2011, 12:43 PM   #1
VA_Camper's Avatar
Trailer: 84 Scamp 13'
Virginia
First post to one of the best communities I've ever joined. I recently purchased an 89 scamp and I'm attempting to drill out the rivets so that I can replace them with SS bolts. Problem is that half of the rivets have the mandrel (nail) sticking out of the head. As a result, the drill bit starts to walk when I try to drill the rivet out. Has anyone experienced this. Any ideas on how beat to handle this? I was thinking a dremel or perhaps a deburring tool. Thoughts?
Thanks,
Al
VA_Camper is offline   Reply With Quote
Old 10-09-2011, 01:42 PM   #2
If you go to an AUTOBODY supply store they do have a special drill bit with a pilot bit that they use In This case
They use them for semi trucks mostly
But I used it on my boler and it worked great
Siris is offline   Reply With Quote
Old 10-09-2011, 01:57 PM   #3
Tim Wood's Avatar
Trailer: Class B for now
NY
Or you could use a Dremel tool, one of their attachments should work out just fine.
Old 10-09-2011, 07:45 PM   #4
Pam Garlow's Avatar
Trailer: U-Haul 1985
I started with a smaller drill bit which stayed centered better. Then once I had the hole started, I switched to a larger one.
Old 10-10-2011, 12:28 AM   #5
VA_Camper's Avatar
Virginia
Thanks for the great ideas. I'm going to try the rotary tool with an aluminum oxide grinding tip first. I'll let folks know how that turns out.
Thanks again,
Al
Old 10-10-2011, 11:17 AM   #6
Trailer: 74 Boler
When I did my windows I had that issue with a few of the rivets, I used a small punch and hammered the pin inwards to allow the drill bit a spot to seat...worked well for me
Brian Tin is offline   Reply With Quote
Old 10-12-2011, 10:30 PM   #7
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Quickest, easiest, & most economical way is to use a punch.
Larry&Carrie is offline   Reply With Quote
Old 10-12-2011, 10:37 PM   #8
That was my thought.
Byron Kinnaman is online now   Reply With Quote
Old 10-13-2011, 12:48 AM   #9
Lowpaidnurse's Avatar
Try using a cold chisel to severe the head of the rivet off. Then use a center punch to remove the body of the rivet. It doesn't elongate the hole or dig into the fiberglass. I've also drilled through the center of the rivet and removed them that way also.
Lowpaidnurse is offline   Reply With Quote
Old 10-15-2011, 11:16 AM   #10
VA_Camper's Avatar
Virginia
Thanks again for the great feedback. Hopefully this thread is useful for folks that end up encountering a similar problem. I ended up grinding down the head and mandrel with my rotary tool. Then used a chisel to cut off the remainder of the head. At that point I punched the body through.
I was kind of surprised to see so many of the nails poking out from the rivet. I would think that would be an exception to the rule but on my Scamp it seems to happen with more than half of the exterior rivets.
This is my first time renovating a scamp (or any trailer) so I'm sure this was just the first of many questions I'll have for the group.
Thanks again,
Al
Walking the dog Roger C H Jokes, Stories & Tall Tales 1 02-25-2011 04:21 PM
Importance of Walking Roy Bakehorn Jokes, Stories & Tall Tales 0 08-04-2009 06:33 PM
Scared to drill! Adam S. Problem Solving | Owners Helping Owners 9 06-11-2009 04:56 PM
The Importance of Walking Ron Wrighton Jokes, Stories & Tall Tales 0 03-06-2009 10:34 AM
