Drilling into Fiberglass with a hole saw. WARNING - Fiberglass RV
Old 05-04-2012, 04:28 PM   #1
Trailer: 1978 Trillium 4500
Today I learned that fiberglass is really tough stuff.
I was using my 18v Dewalt drill as a 1" hole saw. The hole saw has an approx 1/4 centering bit, that enters the material first.
Surprisingly, after I started slowly, then ramped up to high speed, the centering bit got part way into the fiberglass and then suddenly seized up, causing the drill to torque violently out of my grip. The force was great enough to shatter the hardened steel of the bit.
Upon reflection, it appears that the bit is too good at biting into the material. A slower approach, slicing less deeply into the material yields better (less violent) results. I accomplished this by using the drill on a quite slow speed.
The hole saw blade didn't seem to mind higher speeds.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 05-04-2012, 07:32 PM   #2
Placing Masking tape over the spot you will drill tends to keep the edges smother.
Always wear a dust mask because of the GLASS Dust.
Old 05-04-2012, 09:01 PM   #3
Trailer: 19' Scamp
Nebraska
Cocking the drill or breaking through probably had more to do with the catching and binding than the bit did..
Once the saw started cutting the larger diameter tends to keep things squared up.
But then that is drilling with a hand drill.
Earl E. November is offline   Reply With Quote
Old 05-04-2012, 09:10 PM   #4
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
Hum. So instead of hiding a little portable air conditioner in the closet and venting out the wall I should cut a hole in the plastic window instead. Thank you for the heads up!
Sue and Henry is offline   Reply With Quote
Old 05-04-2012, 09:51 PM   #5
Sue and Henry:
You can cut through the 'glass, I cut three holes for water, electric and lights. Just watch out and go slow as needed. ;-)
Cheers
--Fred and Natalie
Old 05-05-2012, 05:34 AM   #6
When using a hole saw on vinyl siding and thin fibreglass run the drill in reverse. The material is soft enough to be cut and the drill won't grab.
Eddie
Eddie Longest is online now   Reply With Quote
Old 05-05-2012, 09:17 PM   #7
Name: Sue and Greg
Thanks Fred, Natalie and Eddie - so much to learn!
Old 05-05-2012, 09:33 PM   #8
Trailer: 2008 13' Scamp
To put to rest any fears people might have gained from this post I have to say that I've being working with many fiberglass projects, including large fiberglass boats all of my adult life. The event described has never happened to me and I've drilled thousands of holes with standard bits and hole saws. As has been mentioned sometimes a bit will grab as it breaks through the bottom of the hole but that's true for many materials.
So I'd say, if you have a hole to drill, do it without worry, it's easier than drilling some other materials.
One trick I do for using handheld hole saws is: use a 3/16" bit or whatever size the bit is in the hole saw and drill the hole. I then use the hole saw with a 3/16" smooth rod. There is less danger, when drilling freehand, that the drill bit will work sideways and make the guide hole sloppy and provide less guidence for the hole saw. Hope that makes sense
Ron
Old 05-05-2012, 09:41 PM   #9
Ed Harris's Avatar
Eddie
Exactly,running in reverse will prevent blowout on the back side.
Tips for Drilling Holes in Fiberglass Lil M. Modifications, Alterations and Updates 33 08-17-2012 05:46 AM
Drilling hole in UHaul floor - sealing Thomas G. Modifications, Alterations and Updates 4 12-22-2011 06:21 AM
Great way to fill a fiberglass hole Stacy Crotser Care and Feeding of Molded Fiberglass Trailers 16 10-14-2011 04:28 PM
