I have one of the rare VTs which have two tables neither of which uses the cone or socket. The CT options are either to surface mount a socket which stands above the floor or use the socket which fits into a hole drilled through the floor that ends up more or less flush. Or to mount the socket on a stabilizing movable plate with no drilling. The support tube can be purchased in various lengths or cut to fit.
You might want to join the
Uhaul Facebook page where you can get specific info from more than 600
UHaul enthusiasts most of whom are CT owners
