Drop Axle Turned Upside Down? - Page 2 - Fiberglass RV
Old 04-02-2013, 09:29 PM   #15
Brian B-P's Avatar
I wouldn't consider for one moment doing the work to convert to spring-over without replacing the known-dead springs... maybe that's just me. If the springs need to be replaced anyway, how about putting the existing axle back in without modification - but with new springs - then looking at what you have for ride height and handling, before spending any time or money on modifications?
Old 04-02-2013, 09:50 PM   #16
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I haven't seen any evidence of them being bad. If so, I agree. They look like regular trailer springs to me. Ideally, the flatter the spring, the better, although mounting can force a change.
Does anybody have a picture of stock boler springs with weight on them? the only thing I've seen is the ones with the unsprung weight hanging, which doesn't mean much.
Old 04-03-2013, 01:58 AM   #17
Trailer:
I would like to see a video of this arrangement passing over bumps, as I think the axle must be waggling around a lot - forwards and backwards as well as up and down. It is effectively cantilevered below the springs so the load on the springs must have been big.
But on the other hand, it's interesting to know that doing this doesn't cause the trailer to burst into flames, get hit by thunderbolt, etc, etc. And presumably it tows OK?
Old 04-09-2013, 02:31 PM   #18
Trailer: Boler 1700
Thanks for all the comments. As far as I can tell I think I've got two options I'm comfortable with. If the electric brakes work (I still need to test them) I will buy new springs and components to return the axle to its original position. If the brakes don't work I'll just buy a new axle with brakes. If they do work I'm wondering what the spring sizing is like. It looks like most springs are 25 1/4 center eye to eye. I have found springs from princess auto that look like a good fit, let me know what you think (see link below)
1,750 lb 4-Leaf Double-Eye Trailer Spring | Princess Auto
As for how the trailer tows. When I purchased the trailer I dragged it 90km from surrey to abbotsford and it towed great, no wobble. That being said I did not have a camera set up to see the axle in action. I know the current set up isn't ideal, but I believe its been run that way by the PO for quite some time.
KeesV is offline   Reply With Quote
axle
A question of voltage drop glamourpets Electrical | Charging, Systems, Solar and Generators 39 12-12-2012 10:03 PM
Lurker turned member Cadet85 Hi, I am.... 9 07-12-2011 07:08 PM
Drop Hitch Wally P. Towing, Hitching, Axles and Running Gear 5 07-07-2010 07:29 PM
Pumpkin Upside Down Cake Donna D. Camp Cooking, Food & Recipes 1 12-16-2005 08:34 PM
Turned my S into a Scamp! Legacy Posts General Chat 5 07-09-2003 08:24 AM
