Dual Propane tank warning - Fiberglass RV
Old 01-02-2006, 12:44 AM   #1
Isaac M's Avatar
Trailer: 1988 19 ft Scamp
I just learned something new with the dual propane tank system on our 1988 Scamp (we do have the new style tanks). I finally got the water system working on the Scamp this summer, but never fired up the hot-water heater. Since we only used the propane to cook, I removed one of the propane tanks to save weight (plus, we didn't even make a dent in one tank all summer).
I assumed that the pressure regulators that were on the trailer worked as one-way valves and would automatically prevent propane from the other tank from escaping. I had capped the line on the tank that I removed, but it was not a super tight seal. A little while ago, I tried firing up the heater and the water heater and couldn't get them to light. So I took it to the local RV shop and had them go through it.
Turns out that there was some propane leaking out the capped valve. It allowed enough pressure to build in the system for the stove to work fine, but not for the heater or the water heater. Thankfully the leak was outside and never allowed enough gas to accumulate to be dangerous (or even smelled). After hooking up the second tank, everything worked perfectly.
I guess some of the newer RV propane systems do automatically shut-off one side if the tank is removed, but many others don't.
So, if your system is setup for two tanks, be sure to have the correct safety precautions in place if you decide to run the system with one tank removed. I'd hate to see someone get injured.
Isaac M is offline   Reply With Quote
Old 01-02-2006, 10:45 AM   #2
Jay Herb's Avatar
Isaac,
thanks for the tip, or you can get a single propane tank regulator.
When ever you do work on the propane system you need to check for leaks , with a leak tester. Jay
Jay Herb is offline   Reply With Quote
Dual propane tanks for uhaul Judith Kennedy Care and Feeding of Molded Fiberglass Trailers 15 09-23-2009 06:44 AM
DUAL PROPANE REGULATOR - For Sale Marv Watson Classified Archives 0 09-15-2009 09:49 AM
PROPANE TANK JIM DUNNE Problem Solving | Owners Helping Owners 5 05-17-2009 07:19 PM
2000 Scamp 16' toilet, bunks, a/c, hot h20,dual propane KirkG Classified Archives 2 07-05-2008 06:27 AM
Propane tank install Robin H Problem Solving | Owners Helping Owners 1 07-09-2007 03:22 PM
