dump valve - leak at knife valve - Fiberglass RV
Old 09-16-2011, 09:58 AM   #1
Trailer: Previously owned a Scamp 13'
New Hampshire
Hi, I have a new problem to solve before my BIG fall trip 1,000 miles from New England to Ill. It seems that the knife valve on the black tank is leaking. When I remove the cap, the space between cap and knife valve has filled up with "water". Very embarrassing!
Any suggestions? Is there a gasket in this valve, or am I looking at replacement?
Thanks!!
Doghaus is offline   Reply With Quote
Old 09-16-2011, 10:20 AM   #2
You can replace the entire valve blade assembly if you want. Four screws hold the two parts together. You can also just replace the gasket. Frankly, I think the whole assembly is cheap enough, that making sure you don't pinch the gasket when installing alone may be a PITA: Amazon.com: Camco 39513 RV 3" Waste Valve: Automotive. These are available at most RV parts places.
Old 09-19-2011, 10:08 PM   #3
Trailer: 1977 17' Boler
Saskatchewan
Leakage
Thanks!!
I have found that keeping the knife blade and gaskets clean that they keep working for a lot longer than they probably should. Everything has a live span (me too). I use vasoline on the sliders and gaskets and all is good. They get sticky with junk and need regular maintenance. Been at it for 25 years nowand all is good.
Greg Boler77
Boler77 is offline   Reply With Quote
Old 09-29-2011, 11:30 AM   #4
New Hampshire
Replaced it, used it, working nice and easy now, with no leaks! Thanks again!
-Heidi
Sink drain valve MyronL Modifications, Alterations and Updates 31 07-10-2019 01:22 AM
Dump valve rearrangement? Joe in MN Plumbing | Systems and Fixtures 10 10-20-2010 06:58 PM
Tire Valve Recall Darwin Maring Towing, Hitching, Axles and Running Gear 13 08-16-2008 06:41 AM
Relocated dump valve Mike Taylor Modifications, Alterations and Updates 3 11-14-2005 03:26 AM
Black water valve leak Legacy Posts Problem Solving | Owners Helping Owners 0 04-28-2003 06:19 AM
