Duo-Therm furnace: Thermostat does not shut off heat - Fiberglass RV
Old 11-22-2013, 12:58 PM   #1
Trailer: Tow Low
1970's Duo-Therm trailer furnace. Worked well until a very cold wet trip, around midnight the temperature was close to 90F in the cabin, furnace thermostat appears to have failed in the on position.
This is a Duo-Therm 11HRU LPG unit without external thermostat.
Question 1: Where is the thermostat hidden?
Question 2: Where is a replacement available from?
MrJoeG is offline   Reply With Quote
Old 11-22-2013, 02:19 PM   #2
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
That little black knob below the red knob is basically your thermostat. It is integral with your main valve. There is probably a probe looking device that is the temperature sensor.
It is that metal thing kind of coiled up in this this picture.
You may need a new valve. Probably worth having it checked out by a pro.
Here's a chart showing replacement valves for your heater.
http://www.ntpdistribution.com/PDF/V...kchart1of2.pdf
Spanke
Trilliums Rock!
Old 11-22-2013, 03:03 PM   #3
Trailer: Tow Low
I located the probe. Are these replaceable or is valve assembly replacement the only viable option?
Old 11-22-2013, 03:14 PM   #4
David Tilston's Avatar
I am not familiar with your furnace, but I think that what you show in your picture would be the thermocouple for the pilot light. Not the temperature sensor.
Old 11-22-2013, 04:01 PM   #5
Trailer: Tow Low
I found the sensor (just like your photo), it is on the back of the control valve
furnace
Duo Therm Furnace Settings Chris McVeigh Problem Solving | Owners Helping Owners 22 01-28-2017 04:41 PM
Duo-Therm Cool Cat Heat Pump Dave Baston Modifications, Alterations and Updates 14 01-14-2013 10:39 PM
duo therm furnace...uhaul Bruce Thomas Problem Solving | Owners Helping Owners 4 04-25-2011 03:36 PM
Duo-Therm RV furnace for sale Marv Watson Care and Feeding of Molded Fiberglass Trailers 0 04-20-2009 05:21 PM
Duo-Therm Gravity Furnace Jake Jacobson Classified Archives 1 11-10-2008 04:13 PM
