Duo-Therm heater - removing the cover - Fiberglass RV
Old 05-10-2006, 10:16 PM   #1
WendyM's Avatar
Trailer: Trillium 13 ft
OK, so now I'm having difficulty opening the cover of the heater....
I pull on the black knob at the bottom and it sticks at the corners. I've used WD40 - maybe I need more? Im wondering if I'm supposed to pull up on it (so it pops up) or pull it out and off completely....Again, afraid of breaking something...
I've checked the manuals in the Document center, but they dont really address anything this basic....and yes, Im starting to feel like an idiot.....
WendyM is offline   Reply With Quote
Old 05-11-2006, 06:50 AM   #2
Trailer: Trillium 5500 1980
I pull on the black knob at the bottom and it sticks at the corners. ....
I don't have the same model but I had a problem most probably similar to yours. My cover was a kind of "press fit" which was a nightmare to open especially when warm. I made a modification and added hinges and a sliding lock. Now it opens and closes like a charm.
Normand Choiniere is offline   Reply With Quote
Old 05-12-2006, 11:30 PM   #3
WendyM's Avatar
Thanks! So on yours, you just pull it straight out and off altogether? It doesn't 'flip up'?
More WD40 I guess.....
Old 05-13-2006, 09:01 AM   #4
That's it! I would remove the door and check what's wrong with the hinges as it seems that you have something like hinges. WD40 surely is evaporated when you heat the trailer...
Old 05-13-2006, 09:51 AM   #5
Trailer: 86 Burro 17 ft Widebody
Wendy,
That lower cover is only held in by side pressure. There are no hinges unless someone modified it. It is merely a tight fit and it will pry out. Get a wire coat hanger and bend a hook on the end, work the hook into the lower corners and tap (with your hand, away and out).
Good luck.
Rick F. D. is offline   Reply With Quote
Duo Therm Furnace Settings Chris McVeigh Problem Solving | Owners Helping Owners 22 01-28-2017 04:41 PM
Paint for hot water heater cover timmckee Care and Feeding of Molded Fiberglass Trailers 4 04-26-2010 07:53 AM
Trillium 75 Duo Therm Heater Asbestos? Kirsten M Problem Solving | Owners Helping Owners 1 05-20-2009 09:33 PM
Duo-therm parts bill m Problem Solving | Owners Helping Owners 12 04-13-2009 08:48 AM
Duo-Therm Gravity Furnace Jake Jacobson Classified Archives 1 11-10-2008 04:13 PM
