E-Z-Lube axles - Page 3 - Fiberglass RV
Old 03-19-2013, 07:32 AM   #29
Brian B-P's Avatar
Originally Posted by Ray N View Post
After I re-packed the bearings for the first time the hub seemed to run hot for the first several hours and then cool down. It was a manual re-pack, not with the E-Z Lube feature. I decided I might be packing them too full. Have any of you run into this? Is it possible to pack too much grease into the bearings?
E-Z Lube completely packs the volume inside the hub assembly under some pressure, which is certainly vastly more than necessary, but at least establishes that it could not be possible to manually over-fill the hub with grease.
On the other hand, it is certainly possible to adjust the bearings too tight, and to improperly seat the bearings which causes them to loosen up with use.
Why two axles???? Francesca Knowles Towing, Hitching, Axles and Running Gear 107 02-23-2013 09:39 AM
To lube or not to lube, THAT is the question... Doug Mager Care and Feeding of Molded Fiberglass Trailers 14 08-19-2011 06:26 AM
Oil Bath Bearing Lube Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 13 04-10-2009 02:09 PM
al-ko axles Dan B Problem Solving | Owners Helping Owners 2 06-02-2008 10:44 PM
Bearing Lube Systems Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 3 05-22-2008 07:57 PM
