Eeeeeeeeee Drain Help needed - Fiberglass RV
Old 02-13-2015, 09:18 AM   #1
BatDude's Avatar
Hi all,
I have had several issues with the gray water tank connection on our 16' Scamp.
The first cap that came with it had one locking tab break off shortly after we received it. I replaced it then a tab broke off on one side of the replacement as well.
OK, so that is not a real big deal as the cap remains in place when traveling.
The important issue is just now when when connecting the drain hose to the black water tank (small really) to drain it first thing this AM I noted that a tab on the drailn connector was also broken off.
So on draining the black water tank (so far only liquids in there) it leaked all over my shirt sleeve etc.
I will go buy a replacement this AM but really wondering why this is happening.
Any ideas or suggestions for the long time gurus?
Still lov'n our Scamp
BatDude is offline   Reply With Quote
Old 02-13-2015, 09:36 AM   #2
I can't guess "What's goin' On' without seeing it, but I would guess that SCAMP is getting parts from someone that's not making great reproductions of the parts they are cloning???? Which is to say that there is a lot of unbranded Cr@p out there for RV parts, just check on eBay and look where it is shipping from!
Something to make the job easier and less apt to break the tabs is to lubricate the seal inside the cap and grease on the tabs so it places less stress on the tabs when removing & installing
Apart from that, I would suggest getting new caps, with the small "Garden Hose" connections, so you don't have to remove the entire cap then draining the gray tank and can easily drain off liquid from the black tank to make room when needed.
Old 02-13-2015, 11:25 AM   #3
Trailer: Casita 17 ft DLX SD
Living in Michigan ,I am assuming it is winter and cold . Some plastics become extremely brittle at low temperatures . I broke the sewer cap on our old Scamp when I tried to take it off at 16 below zero. I did not have that problem when the temperatures were more reasonable. I worked at several plastic molding plants and as Bob noted the quality varies greatly. The problem may be the type of plastics used , casting temperature of the plastic or how much scrap plastic they recycle into the product.
Old 02-13-2015, 07:34 PM   #4
BatDude's Avatar
Hi all,
This happened with the unit was new, then again later on our way south and just again in 80 F temp in southern Calif.
Old 02-13-2015, 09:24 PM   #5
Who are you?
I'm not going to apologize. This is a really friendly and helpful group. The least you can do is tell us your human name in your signature and tell us the year/size of your trailer.
Help us help you!
Old 02-13-2015, 09:35 PM   #6
Originally Posted by BatDude View Post
Hi all,
If its as you say a new unit then I am going to suggest that the fitting on the outtake is to blame - possible misaligned in the manufacturing process? Call Scamp and have them arrange to have it replaced someplace near you.
Old 02-14-2015, 12:43 AM   #7
Trailer: 16' Scamp
Washington (dry side)
I broke tabs on my scamp until I figured out I wasn't pushing the cap on all the way before twisting. Now I fully seat the cap, then twist and haven't had any more problems. (Maybe replacement caps are better quality too)
Jallen is offline   Reply With Quote
Old 02-14-2015, 05:15 AM   #8
papa-t's Avatar
Glade Valley, North Carolina
Originally Posted by Donna D. View Post
Who are you?
Help us help you!
Maybe he's really BatMan. Ok just messing around. I can say in 16 years of camping I've never broken one of these tabs off (yet). But you might not be seating the hose on all the way before twisting. Is this possible as Jallen suggested ?
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 02-14-2015, 08:11 AM   #9
BatDude's Avatar
Tnx all,
Late yesterday I purchased a different hose connector with 4 locking tabs so hopefully that will solve the issues. I will also make sure it is seated all the way before twisting.
Donna D. ??? not sure what your last name is, but clearly last names are not relevant ;-)
On that note I am not sure why my "Public profile" is not displaying as that includes trailer info e.g. Scamp 16' and the fact that wife and I are conservation biologists. I do bats and she did jaguars (cats not cars) when were lived and worked in Central America for the last 25 years. We have NOT been doing well in Michigan for the past 3 years since returning to the U.S. hence why we are now traveling south.
Actually we are working on a bat project as we speak and based for a few weeks in Blythe, Ca. on the lower Colorado River. So Bat Dude is still appropriate.
And for "Full Disclosure" with first and middle name omitting last name I am Bruce Wayne.
Old 02-15-2015, 07:43 PM   #10
BatDude's Avatar
Lessons learned Black water tank
As I noted Friday I picked up a new 4 lug drain hose connector.
The clerk at the RV supply store (also a warranty repair station for Dometic etc.) suggested I come back Saturday to talk to owner.
So mid morning we trundled over and met the owner and service person.
I explained my dilemma and that I was a clueless Newbie to RVing.
I discussed I thought purchasing a drain cap with the standard garden hose connection would be great for the gray water, then use our main drain hose for the black water so it would not fill the small tank.
Another lesson learned!!!!
The fellow suggested I do not do that, as he makes his living charging top $$$ cleaning out folks RV black water tanks that have been drained continually. This leaves solids behind that do not flow out as the liquids drain continually.
So eventually a lump of solids hardens and needs to be cleaned out at premium prices.
His recommendation is to let the tank fill then drain as normal and all will be drained AKA Flushed at one time.
So I did not buy new connectors and am good to go with what I have on hand.
This Newbie is on the steep end of the learning curve.
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Scamping, painting and mentoring students
Old 02-15-2015, 08:32 PM   #11
I have seen very large RV black tanks that needed "Professional" cleaning with several weeks of waste left to solidify after liquid was drained off, or the RV was parked for months and the liquid evaporated out the vent tube leaving a solidified mess in the tank. Keeping in mind that your Service Guy's advice is correct for a perfect world when you always have a dump station nearby when you need one. Lacking that, here's a few tips to add to my post #2.
Using the small fitting on the gray cap for draining will create no problems for the gray tank unless you start dumping all kinds of solids down the drain like chopped fruit/veggies or don't clean solid food off of plates before washing, then it will clogg the small opening and you will have to remove the entire cap and use the larger hose..
My suggestion to also put a cap with a small drain fitting on the black tank was so you could easily drain off some liquid from the black tank in the event that it was "Full" and there was no easy way to dump the entire tank. Of course it's up to you to be sure it gets properly drained and cleared after that.
And the Poor Mans/Smart RV'ers solution to the residue build up in the black tank is to pour 15 lbs of ice cubes into the toilet, add water, drive around a bit, and then drain. Breaks up and cleans it out every time.
Old 02-16-2015, 05:50 AM   #12
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Do Ice Cubes in the RV Black Tank Really Work?
Jason
If you think you are to small to make a difference just try sleeping with a mosquito –- The Dally Lama
kirkman is offline   Reply With Quote
Old 02-16-2015, 09:07 AM   #13
I guess, if you are using NASA certified substitute waste, and need immediate gratification, that ice cubes may not be a solution. But, for the thousands of RV'ers that have been using the ice cube trick for years, it seems to be effective.
I would think that it's reasonable that you should first add some water and let it soak for a while, even overnight, before throwing in the ice, and that's still a lot faster and cheaper than having Joe's RV Service do it for you.
As I have mentioned before about certain videos, "Scientific Method" seems to be an unknown concept in the testing protocols used.
Old 02-16-2015, 09:37 AM   #14
Artificial
Bob ,the material used in the ice cube test shown on the You Tube video is very similar to what is used to test /certify water closets for their ability to evacuate human waste. We have used dishwasher detergent designed for cleaning food waste off of dishes in our black and gray tanks with success . The detergent is easy to store,easy to use , is light weight and cheaper than a bag of ice.
Atwood drain plug leak - Help! spartacus Plumbing | Systems and Fixtures 10 06-29-2014 07:46 PM
hunter help needed / walls HELP xmansurfer Problem Solving | Owners Helping Owners 4 03-13-2013 07:02 AM
Help, I need a chicken and a drain flap flatfendershop Plumbing | Systems and Fixtures 16 04-15-2011 05:34 AM
Help needed for Campster lock and propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 11 06-09-2009 06:44 AM
help needed for led bulb stuff curtis c Problem Solving | Owners Helping Owners 5 05-31-2009 10:21 PM
