Electric anode Casita - Fiberglass RV
Old 10-22-2019, 09:35 AM   #1
My son was going to change the anode and discovered the anode has an electric connection. Inquiring to a rv repair friend said this is an aftermarket add on to heat the water electrically. Now what? Do I get rid of it? I’ve never used my water heater in the time I’ve had this 2001 casita and want to dry camp, so will use the shower
There is a flat plug on an extension cord that comes up through a seat to an outlet. I assume this is to use with shore power to heat water. Is this a big problem?
Do I just use this to heat water when I have shore power and forget heating water by gas? No paperwork for this found, no idea what to even look for online to get more information.
Leej is offline   Reply With Quote
Old 10-22-2019, 10:21 AM   #2
I installed one of these in our Casita 17. I think there is a couple different companies but the one we have is called Hott Rod. Bought it on Amazon. It replaces the anode rod in the water heater, so if you are not going to use it, it may be best to pull it out and install a new anode rod. There also should be a temperature sensor that sticks on to the water heater tank (insulation had to be cut away) that is part of the installation. We almost always camped where there was electric hookup so it worked good for us
Old 10-22-2019, 10:36 AM   #3
AC0GV's Avatar
Wisconsin
Electric water element
Most new anode rods are cheap ($5) and depending on the brand you have; the aftermarket heating element will not break the bank ($25?). If it is a quality installation with thermostat, Id replace it, if not you could save some money and put the rod back in. This one?? https://www.amazon.com/Camco-Hot-Wat...00BFU7QQ0?th=1
Old 10-22-2019, 12:52 PM   #4
Ill try it first
This is new territory for me..wow, I could have had easy hot water where I had hookups. Who knew.
It does resemble the item in the link, but has more to it.
I will plug the trailer in and give it a try before I discard it...it looks like a professional install according to my tech savvy son.
I already bought a replacement regular anode so I will hang onto it. The man I bought my trailer from said he never used the water heater, so it must have been an upgrade by the original owner
Thanks for the replies.
Old 10-22-2019, 01:30 PM   #5
Trailer: 2014 Escape 21, Lil Joe
Conversion kit anodes
Camco makes Anode bushings to work with water heater conversion kits. They replace the thread adapter that comes with the kit. Camco P/N 11645 is the 3/4" anode bushing for the Suburban W/H. The 1/2" version is for the Atwood W/H. You can keep your 115V conversion kit.
Eddie
https://www.amazon.com/Camco-11645-R.../dp/B016MXACRY
Eddie Longest is online now   Reply With Quote
Old 10-22-2019, 03:08 PM   #6
Some water heaters should not have anode rods installed.
Those with aluminum tanks should not.
IIRC.
Old 10-22-2019, 04:34 PM   #7
IIRC.
I don't understand. Why not?
What goes in the hole in an aluminum tank? One wouldn't use an aluminum anode. From the web: Magnesium for fresh water ONLY: Since fresh water is much less conductive than salt water, magnesium anodes are the best choice because they're more active (less noble) than zinc or aluminum
Old 10-22-2019, 05:02 PM   #8
An anode rod is a solid metal cylinder that gets screwed into a water heater’s drain plug to prevent the steel water heater tank from rusting inside. They are made from aluminum, magnesium, or zinc, all metals that will “sacrifice” themselves through electrolysis and save the exposed steel water heater tank from a similar fate.
If you have a Suburban water heater, the tank is porcelain-lined steel and requires an anode rod to prevent corrosion of the steel tank. If you have an Atwood water heater, your water heater tank is aluminum and does not require one.
suburban-anode-water-heater-rod
Important Note: We have read about Atwood water heater owners who have installed anode rods in their drain plugs to prevent the steel threaded drain insert from corroding. This has been reported to be a source of potential leaks as the steel drain insert can eventually rust.
Adding an anode rod to an aluminum tank will actually increase the problems.
Old 10-22-2019, 09:36 PM   #9
Raspy's Avatar
Trailer: Black Series HQ19 on order
Smith Valley, Nevada
IIRC.
Maybe this explains why my tank has a plastic drain plug. I Don't know what brand the water heater is yet, or the material it is made from.
casita
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 06:24 PM
Casita water tank anode Ed in Pensacola Problem Solving | Owners Helping Owners 3 12-06-2010 05:41 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
Anode Rod winterizing question? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-18-2002 09:03 PM
