Electric Brake Control for Subaru Forester - Fiberglass RV
Old 10-22-2007, 06:43 PM   #1
Hi-
Sorry for all the questions. First post, and this is all somewhat new to me. I'd rather get the correct info upfront than go ahead and do this THEN learn the easy way.
I'm in the process of getting an electronic brake control for my '03 Subaru Forester. A few questions:
Any recommendations on the model to get?
Any reccommendations on where to mount the unit? I've looked at the clearance between my legs and under the dash and there just isn't a lot of room. I assume you want to have easy access to it for adjustments and whatnot.
Any tips on wiring it up? I've got a direct line from the battery to spare tire well that controls our marker lights for the 4-pin trailer hook-up. Is it easier to run this line back up to the front or is there an easy route through the firewall? Also, what is the easiest way to tap into the brake lights? I found the switch by the brake pedal, so I'm assuming this is the spot.
One more question: What is the minimum gauge wire that you need to run from the car battery to the trailer battery, and is it necessary to have some sort of circuit breaker between the two?
Thanks,
Todd
Todd Sleeman is offline   Reply With Quote
Old 10-22-2007, 08:55 PM   #2
Trailer: Fiber Stream
Talking
Can you get someone else to do it? That would be "the easy way" in my book...
sorry... That's what I did.
In my pigtail with the molded on 7-pin connector, The (White) Ground wire and the (Black) charge line are each 10 gauge. I would take that to be the minimum.
Old 10-22-2007, 09:25 PM   #3
Todd:
I've used a couple of different electronic brake controllers, and the Prodigy by Tekonsha has been by far the best, in my experience. Because it is not sensitive to fore and aft leveling it also lends itself to less than permanent mounting.
The charge and ground wires should be at minimum 10 gauge. If you need serious charging 8 gauge and even 6 gauge would be beneficial.
Old 10-23-2007, 07:01 AM   #4
Trailer: Love Bug / Chevy Astro
Todd-Do you have a standard 4-pin trailer connector or an extra one that you are hooking your markers up with? The standard connection should have the markers come on with the tail lights of the car.
White wire=ground
Brown=tail lights/marker lights
Yellow-left turn signal/brake
Green=right turn signal/brake
If your car has seperate turn signa/brake lights you would need to get a converter that combines the turn/brake function. I recently found a great one made by Hoppy (Hopkins) at Wal-Mart for about $14. It looks like a slightly overweight 4 pin connector but has the solid state converter built in. Mine works great without a bunch of rewiring.
Bob Cupp is offline   Reply With Quote
Old 10-23-2007, 12:16 PM   #5
Brian B-P's Avatar
Yes, I think that's important. It is an addition to the operator's controls of the car, and should be reachable and visible without difficulty like the rest of them.
I can't think of any of the four wires in a 4-pin trailer hook-up which are useful for the brake controller: the combined stop/turn lights are not the brake signal you need, there is no power source, and the ground connection is too indirect and very likely much to small.
Even if there is not an easy route through the firewall, that's where you need to go, with power and ground wires (normally black and white). The brake signal is just under the dash area, and the output (normally blue) can go to the back either inside or outside of the car (I went back out the same firewall hole as used for power, and then to the back underneath).
That's the normal approach, and it is what I did.
Old 10-23-2007, 01:12 PM   #6
Trailer: 2006 17 ft Casita Spirit Deluxe
I took the easy way out! I bought a Prodigy Brake controller online and saved enough to pay a professional to install it and wire everything for my trailer. I didn't even have to get my hands dirty!!!!! It's done correctly and any problems will be tended to by a professional......................which I'm certainly not when it comes to wiring.
Chris C is offline   Reply With Quote
Old 10-23-2007, 09:03 PM   #7
Trailer: Escape 5.0 (sold) :(
Todd,
Maybe I can summarize, without going into too much detail.
If your Subaru has the factory (or factory-like from third party) trailer wiring, you have everything you need, including the power converter, to control the lights on the trailer.
You need three (or two) more wires: one heavy-guage from the battery, through a circuit breaker, to charge the trailer battery. Another wire from the battery through the brake controller to the trailer to operate the trailer brakes. Finally, a wire from your backup lights to the trailer backup lights. This one is optional.
Thus, seven circuits, four you have now plus these three. You can get a 4-to-7 connector for the car. Plug your four-wire flat connector into the back of it and then run the other three wires in the car. Then, it will be ready to connect to the trailer connector.
Marv
Marv is offline   Reply With Quote
Old 10-24-2007, 05:30 PM   #8
Brian B-P's Avatar
And the two connections which Marv didn't mention, presumably since they don't extend to the trailer: the brake controller needs a good negative (ground) connection, and the brake signal (from the pedal switch).
Finally, the "ground" connection in the four-way lighting connector is inadequate for either battery charging or electric brake operation, so the 4-to-7 converters (such as the one I use), only use three of the wires from the 4-pin socket, and have separate wires for the three additional circuits which Marv listed, plus a separate ground wire, much heavier than the one in the 4-pin socket.
Old 10-24-2007, 05:45 PM   #9
I would think this would be a case by case thing. I wouldn't want to make a generalization about current carry capabilities or needs. You could be right about needing a larger wire, but a larger wire could already be in tow vehicle connection.
Old 10-24-2007, 06:05 PM   #10
Brian B-P's Avatar
... a larger wire could already be in tow vehicle connection.
I assumed (perhaps incorrectly) that we're talking about the common 4-pin flat connector here. Even if huge wire is attached to it, this "bullet" contact is not good for reliably carrying much current, and the brakes need at least several amps in addition to the lighting plus any battery charging current (it all returns through one "ground" connection). I agree that a generalization may be inappropriate, but the 4-to-7 adapters do typically use a separate ground connection for this reason.
I think if the tow vehicle is wired for high current on the negative wire, it is likely to have full charge-and-brake wiring with a 7-pin connector (like a typical modern "prewired" pickup truck or large SUV), not a 4-pin lights-only connection.
Old 10-25-2007, 12:31 PM   #11
Hi Guys-
Thanks for all great info! I am definately following the thread.
Does this sound reasonable:
I'll be hooking up the brake controller to the positive (with a breaker) and negative of the battery with 10 gauge wire and tap into the brake switch, then I'll be running 10 guage to 'brake' line on my new 7 pin connector. I didn't get an adaptor, but will tapping into the existing 4-pin connector wires for directional only. I'll also run a 10 guage wire from the battery to the charge line of the 7 pin.
In regards to ground, can I use the heavier wire of the 7-pin and just ground to the car frame or should I run a wire back up to the negative of the battery (or is that a big no-no)?
Also, should I install a breaker between the hot-line of the battery and the 7-pin to isolate the car battery from the trailer battery or is there no reason to do this?
Thanks!
Todd
Old 10-25-2007, 12:54 PM   #12
Brian B-P's Avatar
The car's body is likely quite capable of handling the current, but the connection to it is less certain. It can be done either way (separate wire or via the body), but I chose the separate wire.
This could start a long debate, as there are strong proponents of each approach.
A circuit breaker is definitely called for to protect against excessive current due to a short circuit.
A relay (or solenoid) can also be added to shut off power when the car is not running; I think this is a good idea and I put one in.
Old 10-25-2007, 01:45 PM   #13
Be careful of assumptions, sometimes they're not correct. I don't know the current carrying limit on bullet connectors, but I can tell you they are designed to accept up to a 10 AWG wire. The biggest problem with any bullet connector, including 4 and 6 circuit flat connectors used in trailer applications is connect and disconnect forces. They take a lot of force to get fulling connected and a lot of force to get disconnected.
I went to Tyco's web site and discovered that maximum wire size of 10 AWG is wrong. The maximum wire size is 8 AWG.
Edited for added information.
Old 10-25-2007, 03:02 PM   #14
More great info! Would a 30A be an appropriate size for the circuit breaker? Any recomendations on relay/solenoid brands? Any wiring tips that aren't obvious?
Thanks again,
Todd
(figure I should get the car wired right the first time, then work my way back to the trailer...)
Which U-Haul brake controller for Scamp13 pulled by a Forester?? bcomnes Towing, Hitching, Axles and Running Gear 1 12-23-2009 10:44 PM
More Subaru Forester Towing Questions Michelle A Towing, Hitching, Axles and Running Gear 12 04-04-2009 10:18 PM
Subaru Forester Diesel? Bobbie Mayer General Chat 11 03-07-2009 07:23 PM
towing a 13' burro with a Subaru Forester Pamela H Towing, Hitching, Axles and Running Gear 5 07-23-2008 08:15 AM
Brake control(again) TonyB Problem Solving | Owners Helping Owners 12 04-29-2007 06:36 PM
