I have a 13.5'
Bigfoot. I have been using a venturer brake controller. The controller has worked well for some years. There is an indicator
light that shows either red ( not working) and green (functioning ). It
lights up green, when using the 4runner
brakes when hooked by umbilical cord, the trailer
brakes work as well. some times when braking, the
light shows red for some time, as
brakes are used, then it will go to green for no reason. I hooked up to go on a trip, and the
light was showing green. As I accelerated, it felt as if there was something having it's brakes on. I pulled over and felt the trailer brakes and they were cool. I drove about a block farther, and there was some vibration; from where ??? I pulled over and put my fingers in past the wheels and touched the the disk on one of the rear brakes. ----very hot!!!! The 4runner worked well before the hook up. I disconnected the connection under the dash, and every thing worked fine. I didn't look at the color of the light.. The controller seemed to be operating the Tug and not the Toe. It was controlling the 4runner brakes while not applying the brake peddle . Does anyone understand how this was happening? I am going to purchase a different brand of controller!
