Originally Posted by Dan Meyer
Adjust the maximum voltage going to the trailer brakes so the wheels lock up with a full manual brake application. Then back off the maximum just a bit so the brakes are not locked with a full manual application.
The amount of load will determine the amount of brake force needed. An empty trailer will need less force to avoid lockup than one with horses loaded on it. Determine the numerical values for each load situation and set the controller limit accordingly before pulling out.
My 750 lb car carrier has a lot lower brake setting when empty than when the 1600 lb car is strapped on it.
Also be aware that friction will make a difference. Flat, level pavement will permit much higher brake force without skid versus side sloped dirt tracks in a pasture.
Jon MB: Waiting for a trailer add-on ABS system to simplify settings.
