Electric Heater Source - Fiberglass RV
Old 11-29-2015, 03:15 PM   #1
Looks like it would be a good heater for an egg.
http://www.adventurerv.net/broan-nut...bed1e-94452289
Broan Nutone Big Heat Portable Heater 6201
I have bought from these guys for many years.
Old 11-29-2015, 05:47 PM   #2
Dan Meyer's Avatar
Their advertising states: "1500W electric heater delivers more heat than any 120V heater."
I'd like to know how they accomplish this. 1500 watts of heat is 1500 watts of heat.
Save your money. Get a $25 - $30 electric heater from Target or Wal*Mart.
--Dan Meyer
http://scamp.n0kfb.org
Old 11-29-2015, 05:56 PM   #3
Name: Frederick / Janis
Trailer: Previously Scamp 13 2002,2016. Scamp 16 on order
--Dan Meyer
Dan and Dawn's Scamp Travel Trailer
There ya go, complicating things with math and science.
They accomplish this with crystals, prisms, and Amish cabinetry and if all else fails, with smoke and mirrors. Of course, eye of newt is always a favorite.
bpfick is offline   Reply With Quote
Old 11-29-2015, 06:49 PM   #4
I just liked it due to the size and it looks like you can't tip it over.
Old 11-30-2015, 10:33 AM   #5
GMike A's Avatar
I just bought an inexpensive one from Walmart. The one I had before was either off-low-high and it was a PITA as it was always on one of those modes. The one I have now is thermostatically controlled and with a tip over switch and I know it will do the job. I wanted to keep it inside and on low to keep things from going too cold even though the water system is winterized. I will stay out of the thermal efficiency and heat dispersion methods discussions.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 11-30-2015, 01:53 PM   #6
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
It is handy to have a heater that can be set @ 1550 W or 750 W , if you are at a site that only has 15 amp service 750 W leaves room for other uses.
One thing that is helpful for us is an outlet for the heater that is controlled by a line voltage thermostat - then the temp. can be set and held especially nice at night .
Bob in Mb is offline   Reply With Quote
Old 11-30-2015, 02:36 PM   #7
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
This one has a very strong fan and will heat your camper more evenly.
http://www.amazon.com/Vornado-VH2-Wh.../dp/B00006C7HJ
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 11-30-2015, 03:19 PM   #8
Ohio
I have two of these broan heaters. One for the Scamp and one in my bathroom. They work well, however the thermostats ore touchy. Just a tiny movement can change the temp 10 deg. I've never needed the high heat setting even in the coldest weather. They are hard to tip and have a tip safety switch if they do.
cmartin748 is offline   Reply With Quote
Old 11-30-2015, 11:51 PM   #9
Roger C H's Avatar
Smile Our heater
We found this type to be the best. It can be close to the kitchen. The fan ones are noisy, drafty and have the potential for igniting things.
This type, beside being silent does not get hot enough on exposed surfaces to ignite anything.
Name:	Feature Comfort.jpg
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 05:24 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
Installation of an electric hot water heater jrnutpaul Modifications, Alterations and Updates 7 09-20-2006 08:17 AM
Electric heater gregziglar Modifications, Alterations and Updates 1 08-03-2006 11:32 PM
