Electric trailers: Help me decide with side by side comparison - Page 3 - Fiberglass RV
Old 10-05-2015, 08:44 AM   #29
That's my method too Bob...but I take it one step further. In warm weather and the tank is warm, it's hard to tell the difference sometimes. I simply run about a half a pot (4 cups min) through my coffee maker and use it. HOT water but you probably can mark it within 1/4" if you wanted to know exactly where the gas line is .
Do it at your own risk because you're using HOT water. Just be careful when you first touch the tank...especially during the summer. But again, there IS a difference.
Originally Posted by Bob Miller View Post
Actually you don't need the strip....
To use the strip you have to pour hot water on it and it changes colors and gives you an approximate level.
But, if you just pour a cup of hot water on the tank and run you hand up from the bottom, it will be cold where the LP is at and get warm where it's not at. Easy Peasy and slightly more accurate.
Old 10-05-2015, 09:03 AM   #30
Originally Posted by 4x4LDY View Post
LOL, yeah no princess crown here, lol
I need to get that strip to show how much is left in the tank, but with just one weekend left to camp this season, I bought a little ceramic heater just in case I run out. I figured next season I'll deal with the switch over unless I sell before then
Yup the princess thing is not something I am overly good at pulling off either
I have a gauge on my propane tank (purchased from Costco) that I find helps. Not 100% accurate but close enough for me. Once the needle gets close to going out of the green zone its time for a refill.
When traveling on my own I just pull the trailer up close to the refill station (normally a place were I am stopping to buy gas for the vehicle anyways) so I only need to carry the tank a few feet to have it refilled. Once its refilled 9 times out of 10 the party who did the refill will offer to carry it and put it back onto the trailer, all I need to do is reconnect the hose to it and secure the tank. Pretty easy. Actually just had a tank filled yesterday - total elapsed time from time of pulling into the propane refill station to pulling out with a full tank remounted on trailer less than 6 min.
Old 10-05-2015, 09:09 AM   #31
Trailer: Escape 21 Nov.2016
snoozy
We have the twin bed Snoozy very similar to Queen except smaller couch
54in VS. 72in and beds run front to back VS side to side
The bikes go right in the back door I've had 2 large beach bomber bikes in there and just tied them down real good and no problems .
That was one of the reasons we bought the Snoozy.
I wish the Snoozy would be two feet longer and maybe tandem axcels . We have grandkids and need more sleeping areas but for Two its a great setup .
I think each fiberglass trailer has something that owners want and like .The side door give you a nice canopy and place to sit whereas the Snoozy has the rear door no canopy that would act as a shelter . The sizes of the 16 and 17 ft trailers all have about the same inside space from 13-14 ft The Snoozy has the most space compared to Scamp,Casita ,Escape , parkliner and,Egg,These all are very similar in size except for maybe the parkliner which is 15ft and inside about 12ft . Go and look at some of these and then make up your mind .They all are going to be about 2000lb-2500lb to tow so the towing will be almost the same . Good Luck in your Quest .
BTW we have our Snoozy for sale because Grandma wants more room for the Grandkids so its a Quest for a bigger fiberglassRV ?
jennykatz is offline   Reply With Quote
Old 10-05-2015, 09:16 AM   #32
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
In my mind it really boils down to your style of camping. If you will always be in a campground with at least electrical hookups in a nearby location, all electric is fine.
Of course there is always the possibility that you will change your mind on how far you want to travel, or even decide to try boondocking which could throw a monkey wrench into the choice, but there is always a retrofit, or, as has happened to many, a case of 2' itis', and a new trailer!
Old 10-05-2015, 11:44 AM   #33
4x4LDY's Avatar
Trailer: 2008 Fun FinderX 160, wanted Eggcamper all electric
Good to know! I will search the bikes section and see what all pulls up. I have been comparing sizes and so far the snoozy is about a foot shorter in height, but a foot wider in width- but I also know that is the tires on the outside vs under the body, so overall it may seem not as wide
I really wanted to go to the RV show this last weekend but I had a sick kid so we had to pass
4x4LDY is offline   Reply With Quote
Old 10-05-2015, 11:44 AM   #34
4x4LDY's Avatar
Very helpful gents!! Thanks
Old 10-05-2015, 01:04 PM   #35
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
4x4LDY, ;We have a Lil Snoozy, and placing bicycles in it for travel is very simple....they can even ride on the bed. I have added propane to ours for heat and cooking, and use a fiberglass propane tank so I can see the level of propane left in it, and it's lighter also.
Dave & Paula
Old 10-05-2015, 03:36 PM   #36
David B.'s Avatar
Trailer: Lil Snoozy
Old 10-06-2015, 12:54 PM   #37
4x4LDY's Avatar
Thanks Dave for the bike info. I have been on the site all day.....can you say downtime at work :/ bored so therefore I must surf
Old 10-06-2015, 12:59 PM   #38
4x4LDY's Avatar
Snoozy peeps just got back to me and said it could fit 3-4 full size bikes in their trailer That is a positive thing!!!
Old 10-14-2015, 11:55 AM   #39
4x4LDY's Avatar
last weekend and your tips :)
I covered the stove, plugged in a heater and finished my curtains. Thanks everyone, time for sticky to go into hiding for the winter and hopefully emerge in the spring as a new egg!!
a chick waiting for her first egg
Old 10-24-2015, 07:58 AM   #40
MCDenny's Avatar
Trailer: Lil Snoozy
LOTS of info here!! Thanks so much. I currently have surge brakes on the camper I have now so I am familiar with those. I will look at all these items and see what each is. I think for me my initial thoughts on the rear entry were not good since I was thinking about having a hitch for bikes added to the back of my current trailer wondering how that would work if I got the snoozy. My wonder is could I fit a couple full size bikes up the middle of the camper, wrapping them so they don't bump or scratch anything......I guess that is another question for snoozy owners.
Thanks again for all your insight!
We put two full size bikes inside for two full winters of camping. I made a couple of brackets that attached to the front under-bed storage door with wing nuts. Worked perfect, never any damage from bouncing around on the road. Pluses are bikes stay clean and (relatively) theft proof, minuses are kind of a pain to set up and very restricted access forward of the sink with the bikes inside.
Last year we got two folding bikes and keep them in the back of the Jeep. All pluses now, no minuses except the little bikes don't ride quite as well as the old ones.
Check out the Jan 21 2015 post of my blog. www.wanderingourway.wordpress.com for pictures of how the two full size bikes were mounted in the trailer.
I considered the egg camper and in fact live in Michigan not too far from the plant but choose the Snoozy for the warm all wood interior, cassette toilet and more modern foam core sandwich construction method.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Help me decide between a T@B Max and an egg type... CarltonC. General Chat 36 03-24-2015 09:35 PM
HELP:Interior Height Issues/Comparison Missouri Mark General Chat 43 04-01-2014 09:55 AM
New here, help me decide RichardP Hi, I am.... 11 02-27-2014 09:36 PM
Help me decide.... Jim Norman Care and Feeding of Molded Fiberglass Trailers 58 09-26-2010 04:02 PM
help me decide what trailer i need KellyT General Chat 11 04-21-2009 11:04 AM
