Electrical connection to tug vehicle - Fiberglass RV
Old 07-31-2014, 07:42 PM   #1
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
One of the rear red lights on the burro was on last night. The burro was disconnected from the tug vehicle but connected to land electric. It happened before completely free -- so I am assuming it was drawing from the battery somehow. Shaking the plug, it rattles so we purchased a new one and opened the old one. This is what we have:
Brown label has green wire
Black label has black wire
Green label has brown
Red label has yellow
White label is empty, but there is an unattached white exposed copper wire
Blue label has nothing attached
No spot is labelled yellow
We have two wires cut off (blue and red) - copper is unexposed and I assume those are for braking systems. We don't have that on our 13 foot burro.
Should we reconnect to the new plug in the same mismatched order or does someone out there have another suggestion?. Help!
Sue and Henry is offline   Reply With Quote
Old 07-31-2014, 08:11 PM   #2
Borrego Dave's Avatar
Sounds like a short
Old 07-31-2014, 08:31 PM   #3
Roy in TO's Avatar
Hard to tell from lable and wire colours. Check the pins on your tow vehicle comparing them to the standards published on etrailer and the like.
Then test the wire colours on the trailer end trying to match them by pin # to the tow vehicle.
I think Dave is right and it is probably this one: "White label is empty, but there is an unattached white exposed copper wire."
Old 07-31-2014, 09:03 PM   #4
Name: Sue and Greg
Thank you Dave and Roy. I appreciate the help. I'll give it a shot. (Oh my goodness. I had to correct "short" to "shot"). Hope that is not a precursor to something uncomfortably exciting!
Sue
Old 07-31-2014, 09:59 PM   #5
Roy in TO's Avatar
If you are inclined to imbibe.
Make it a short shot before you start.
Keep the long shots until you are finished.
Old 07-31-2014, 10:08 PM   #6
Good one Roy, it's still 102* here in the desert and I've got a cold one open
Old 08-01-2014, 12:33 PM   #7
Name: Sue and Greg
[QUOTE=Roy in TO;473745]If you are inclined to imbibe.
Keep the long shots until you are finished.[
Abiding by your short shot rule, I did it, it seems to work. Yay!!
electrical
trailer electrical connection tartosuc Towing, Hitching, Axles and Running Gear 20 06-15-2013 10:08 AM
U-Haul Electrical extension connection Perk Electrical | Charging, Systems, Solar and Generators 13 06-24-2012 06:09 PM
Tug to Trailer connection Scott B. Problem Solving | Owners Helping Owners 10 08-15-2010 04:13 PM
9-pin electrical connection Legacy Posts Problem Solving | Owners Helping Owners 5 01-06-2003 06:56 PM
