04-12-2011, 10:16 PM
Trailer: 13' Scamp
Electrical issues
Hello,
I have a 1995 13' Scamp that I just bought. Everything seems to be in good condition. However, there is a problem that I just recently noticed. The battery will not charge off the 120v power source. It will only charge when hooked up to the car. All the 120v electrical items work just fine. It's just the two dome lights and the outside light that don't work. I hooked it up to my car for about 10 minutes. Those three lights worked just fine while hooked up to my car but then started to dim shortly after I disconnected from my car. The 120v was hooked up, but the lights still continued to dim. Basically, it seems that the 12v and the 120v systems are only working independently of each other. I changed the fuse by the battery, but it did not change the issues. Any advice would be greatly appreciated.
04-13-2011, 05:56 AM
I don't know if a 1995 converter is the same as a 2009 or not, BUT.
On mine the 120v supply cord for the converter is a normal 120v plug that plug's into the back side of my 120v panel. ( It comes UNplugged )
Also look for a fuse on the converter and make sure the breaker/fuse for the 120v for the converter is on or good.
Bill K
Originally Posted by Clankster
Hello,
04-13-2011, 10:44 PM
Trailer: '78 Trillium 4500
Hello,
Are you sure that you have a converter? Not all trailers of that vintage came equipped with one. Without one, 110 power won't operate your 12v lights. If you DO have one, it may require that you manually switch between 12v and 110 power.
Also, even if you have a converter, if it has no charging function it won't charge your battery.
If you let us know exactly what you have, we can be more helpful!
Francesca
04-14-2011, 05:53 AM
Trailer: 13' Scamp
It very well may be the case that I don't have a converter. That's what I'm beginning to think. I have looked everywhere and this is the only electrical box I can find.
Is a converter a separate unit?
Thanks for your help.
04-14-2011, 09:51 AM
Looks like shorepower to me! I think that's your 110v circuit breaker.
A converter is a separate unit that "converts" 110v AC power to 12v DC. Your 12v lights/pump/whatever-you-have won't work off shorepower without one.
Some, but not all, converters also charge the trailer battery. I think you can buy a combined converter-charger for less than $200.00.
My Trillium came to me with a converter only- I had to add a charging module to it.
Francesca
04-14-2011, 12:45 PM
Trailer: 13' Scamp
That's what I was thinking. I appreciate your input! Thank you for clearing it up for me.
04-14-2011, 02:35 PM
Hello,
FYI:
Here's another little ray of sunshine...NOT
Your above observation deserves a closer look, too. If your battery is getting well-charged by your tow vehicle, your 12v lights should burn just as bright as they do when your t.v. is hooked up (with ignition off). At least, until you run your trailer battery down some. If there's a fan-forced heater and/or water pump in your Scamp, they're probably 12v,too and without a converter will continue to use battery power even when you're hooked up to shorepower. That, combined with your 12v lights, will draw the trailer battery down pretty fast. You don't say what your tow vehicle is, but some alternators don't put out enough juice to fully charge a battery in addition to the vehicle's own. It's more likely, however, that the difference is due to the fact that (as you've just discovered) the ONLY charging your trailer battery is getting is from the tow vehicle, and that your 12v systems must operate from the battery, which probably isn't getting fully charged (short trips?) between hookups to the tow.
Also, if your car's ignition was off at the time you conducted the above test, the fact that you noticed a difference in the brightness of the trailer lights is an indication that you're actually running the trailer 12v systems off BOTH the car and trailer batteries, which are linked as a series. Unless you have a vehicle battery isolator in-line to break that series when the car ignition is off, power is drawn from both batteries at the same rate. This can very quickly drain your car battery below its ability to start the vehicle.
Have a nice day-if possible after all this "good" news!
Francesca
04-14-2011, 09:24 PM
Trailer: Scamp 16 - floor plan #4
I have this exact same issue (everything electrical that's supposed to run on battery or shore power does so, but only the tow vehicle charges the trailer battery) with my 1988 Scamp (new to me last fall).
I too initially assumed that the 120v box under the sink was the converter, but eventually found the converter under the street-side dinette seat (rear dinette). No blown fuses there that I can see, but after reading this thread I think I need to see if perhaps the root cause in my case is that I don't actually have a charger-equipped converter.
04-14-2011, 09:52 PM
Hi, Joe
Been there, done that!
When faced with the fact that my converter didn't have a charging function, I couldn't see any reason to replace it entirely, since it works just fine within its design limitations. Instead, I added a charging module to it, see below. It cost about $80.00, and came with installation instructions. This one might be hard to find, but I've thought since that one could probably add a marine charger such as those sold at any boating store and get perfectly satisfactory results. That solution should also cost under $100.00.
Good luck!
Francesca
04-14-2011, 10:12 PM
Trailer: 2000 Scamp 16 ft Side Dinette Deluxe / 1997 Toyota T-100
Good unit
If you want to add a converter, this is a very good unit, works well and very clean to install.
4000 Series
04-14-2011, 10:17 PM
Francesca and Dave,
Thanks for the good info!
Regards,
Joe
04-15-2011, 02:19 AM
4000 Series
Am I looking at a 15 amp service in "clankster"'s picture?
The smallest unit on this page needs a 30 amp breaker...can't tell if that means it has to have the circuit all to itself.
04-15-2011, 05:43 AM
Trailer: 13' Scamp
Awesome information everyone!!! Thanks so much. I think my plan is to call Scamp and see about ordering a converter at some point. Also, my thinking is if all that is running off the 12v power is the dome lights it won't be that big of an issue. This is a simple little trailer. The only things that would require power are the dome lights, floresent light, heater fan and fridge. Plus, anything we plug into an outlet. I know the fridge runs off of the source. If the heater does too I'll be in ok shape without a converter for now. Thank you guys for all your help!
Clint
04-15-2011, 09:20 AM
Clint
If my Scamp didn't already have a converter I wouldn't pay for one. A battery minder and a smart charger will keep the battery charged better than a converter. The one that Scamp put in my Scamp under charges the battery to keep from overcharging. That's not good for batteries either way.
I use a battery minder type of device when at home to keep the battery fully charged and it has a way of reducing sulfate from building up. If I was to be plugged in more than a few days I would connect the battery minder.
Most of the time when traveling the battery is charged from the tow. If I'm more that 3 or 4 days in one spot without power the solar panel comes out.
From my experience and a couple others on Yahoo Groups it's felt that a converter probably isn't worth the cost.
04-15-2011, 10:24 AM
Trailer: 13' Scamp
Byron, can you tell me more about your solar panels?
04-16-2011, 02:24 AM
You can't run 12v fixtures off shorepower without a converter.
Francesca
04-16-2011, 08:21 PM
Clint if not hooked up the fridge should work just fine on propane - as far as running the heater off the battery goes it tends to be pretty hard on battery power.
04-17-2011, 05:45 PM
The Panel is a Kyocera model KC65T with a Morningstart SunSaver-6 charge controller. I built a stand out of stock aluminum 1" angle stock and 1" flat stock and a couple card table type locking arms. It's set to be at 60° from horizontal, which I understand is about optimal.
The charge controller will NOT allow the battery to be overcharged. They system charges with 4 amp maximum charging current.
I fastened a piece of 1/2 plywood the size of the panel + 4" to two 2x4 on the 2" side. I also a short stop block down from one open end and left the other end open. When I this in the back of my truck the panel with controller will slide under the plywood and stop before it can go out the other side. The tail gate of the truck holds in place. I did cover the plywood with some Rat Fur I had laying around.
Also of not my truck bed has a Bed-Rug in it.
For the battery connection off the controller I put about 15' of #12 AWG dual wire with Anderson Power Pole connectors on the end. I attached a short piece of the same wire to the battery and the same connector on the end. At the moment that wire is coiled on top of the battery with battery box lid in place. When I want to charge the battery I simply open the battery box and plug in. Then put the panel is full sun and move it as needed.
If you have any other questions please ask.
Byron
04-17-2011, 05:46 PM
Francesca
Why not?
You run them off the battery.
04-17-2011, 06:45 PM
Francesca
Why not?
Byron,
Is it OR ???
I can't tell if you really don't know or if you're just being a Mr. Smarty Pants.
I'll explain it as simply and thoroughly as possible, thereby addressing both possibilities:
The battery is a 12v power supply, happily exactly the voltage needed by a 12v fixture.
Shorepower ("hookups") is 120v, which is 10 times more voltage than a 12v fixture needs unless one is trying to set it afire.
Barring that intention, it's necessary to reduce 120v power to 12v, which is ordinarily accomplished by running it through a converter.
What happens to all the leftover voltage after this process (120 minus 12 = 108) I cannot say...
Perhaps it just lies around waiting to be vacuumed up by an inverter, which accomplishes exactly the opposite function: the transformation of 12v power to 120v.
Hope this helps!
Francesca
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Electrical Issues
Debbie Ray |
Electrical | Charging, Systems, Solar and Generators |
4 |
04-12-2011 10:26 AM |
Random Issues
Jeff Peterson |
2 |
04-12-2010 05:27 AM |
Leveling issues
Lisa M. |
General Chat |
51 |
12-20-2007 03:41 PM |
ECO issues
Matt O'Bryan |
10 |
02-20-2006 12:30 PM |
