Electrical not working, help! - Fiberglass RV
Old 07-01-2013, 03:17 PM   #1
Trailer: Trillium 13'
Hi everyone. I'm new to this having just purchased my 13' Trillium last week.
The electrical does not seem to be working? 110 or 12V
I'm not very concerned about the lights as we can use lanterns however I would like to get the fridge running.
There is a blue wire that is coming from the thermostat control knob. It has been cut and is sitting disconnected.
The heater and stove seem to be working off of propane fine and I have tried changing the light bulbs hoping that was the cause....nope.
Any help would be greatly appreciated.
Dupuini is offline   Reply With Quote
Old 07-01-2013, 06:36 PM   #2
Hi Nick, to FiberglassRV, we're glad you're here
There are lots of kind and helpful people here on the forums. They share information and knowledge freely. I'm sure one or two or ten of them will be along shortly.
Old 07-01-2013, 06:40 PM   #3
Trailer: Trillium 4500 1977
Quebec
Hi, Have you checked the power converter ? It has a switch for 12V/110V selection and likely a breaker or a fuse. Usually, there is also a 110V outlet directly on the power converter. Check with an electric tester for AC and DC voltage. The fridge is connected to a 110V outlet accessible inside the RV fridge trap. If there is no voltage there, your 110V breaker might need to be reset. If you connect your fridge directly to a 110V extension cord and select 110V, you can test the fridge to see if it works.
RV of that age often got modified in terms of electrical system. You need to survey everything, find the components and check for connector and cables integrity, including under the floor.
By the way, blue wires can be the electric brake wire. If so, this is very bad news Your RV needs position lights and everything working to hit the road.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Old 07-01-2013, 06:45 PM   #4
cpaharley2008's Avatar
Blue wire from thermostat will have no effect on your 120v circuits. Are you plugged in? Did you test the circuit first?
Jim
Never in doubt, often wrong
Old 07-01-2013, 06:48 PM   #5
Nick, there's a Trillium wiring diagram in the Document Center. I hope this helps: Fiberglass RV - Document Center - trillium 1300 wiring diagram
electrical
CONVERTER not working Adrian W Electrical | Charging, Systems, Solar and Generators 15 07-28-2014 12:21 PM
Led's not working Perry J Electrical | Charging, Systems, Solar and Generators 4 08-21-2012 09:49 PM
Fridge not working on AC Parker Buckley Problem Solving | Owners Helping Owners 11 12-04-2009 08:53 PM
Who's working, anyway? David G. Jokes, Stories & Tall Tales 8 01-23-2007 10:42 AM
Battery - Not Working Jeremy Witt Problem Solving | Owners Helping Owners 7 06-17-2006 09:08 PM
