I reciently had to replace the refrigerater in the egg. A friend of mine saw the old one waiting to be halled off and said that I should remove the 110 volt heating element and I could use it to add electric heat to a water heater that was
propane only. He told me that you slide the element down the tube that the gas burner is in and wire it to a 110 volt power supply. He has many years of R V experience so before I threw the old one away I removed the element.
Has anyone ever heard of this, as it sounds much to easy. Would like to get some input before I try it and cause myself problems that I don't have now.
Thanks
Ron
