Ensolite - Fiberglass RV
Old 03-18-2018, 05:27 PM   #1
Trailer: Currently Shopping
Ensolite
I need to replace some ensolite in a 1976 13 ft scamp. One section has water damage and I'm not sure how to fix it. Can anyone tell me where to buy the ensolite and a type of glue to use?
Jiggs is offline   Reply With Quote
Old 03-19-2018, 05:56 AM   #2
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
You can't get it with the white vinyl facing. You can get it unfaced or with a black facing. Here are a few links:
https://www.scs-interiors.com/ensoli...-material.html
https://www.professionalplastics.com...ITEPVC-NBRFAOM
https://www.foammart.com/p-456-ensolite.aspx
Not sure about the glue. You should be able to find a thread or 12 by searching the forums.
Alex Adams is online now   Reply With Quote
Old 03-19-2018, 06:39 AM   #3
John in Michigan's Avatar
Trailer: 1979 Boler 1700
water damage?
Can you post a photo of the "water damage"? Someone here may post a method for repairing it. Ensolite is extremely tough and impervious to water.
Old 03-19-2018, 06:45 AM   #4
Ensolite
Whatever Escape uses has a white(ish) vinyl top layer. You could contact them, or perhaps an Escape owner knows the specific product. It is smooth, however, unlike the pebbly texture of the original Ensolite. Unfortunate, an exact replacement is no longer available.
You might cut a piece from a hidden area to make your repair. Then patch the hidden area with a different product.
I believe contact cement is commonly used to glue it, but Alex's suggestion of a search is good. Use the "Site Search/Google" at the bottom of the search menu for best results.
Old 03-19-2018, 07:43 AM   #5
Trailer: Trillium 1979 13ft.
Ensolite
Some people have used 3M brand spray adhesive used mostly for automotive headliners and such. Worth looking into...
Butsky is offline   Reply With Quote
Old 03-19-2018, 07:47 AM   #6
adhesive
when I redid some panels in my 40f eagle bus conversion I used the 3m stuff very stinky after awhile! but it works great!
bob
Old 03-19-2018, 07:48 AM   #7
thinking again
I think you could do a u-tube search on this!
good luck
bob
Old 03-19-2018, 07:49 AM   #8
3M77 is not strong enough. I have even heard of a few heat-related failures with 3M90.
Old 03-19-2018, 08:03 AM   #9
I have also used stuff that comes in quart cans used a roller cant recall the name of it but it worked well!
bob
Old 03-19-2018, 08:26 AM   #10
FRED SMAILES's Avatar
Trailer: 13 ft Boler
If it's the same material as in my '74 boler, water may stain it but it can be cleaned. I have no experience painting it but many have with excellent results.
As to glue, I have scraped it away from shell in several areas in the course of different projects and just used run of the mill contact cement with great results.
This mod is 5 years old, glue still good
Fred
FRED SMAILES is offline   Reply With Quote
Old 03-20-2018, 03:53 AM   #11
If you call or email 3M they can point you to the correct adhesive. I've used them several times over the years and got good advice.
lgboro is offline   Reply With Quote
replacing ensolite jojo Problem Solving | Owners Helping Owners 7 05-06-2010 10:31 PM
ensolite replacement Lisa Rynearson Care and Feeding of Molded Fiberglass Trailers 5 04-10-2006 06:46 PM
Ensolite paint Dan Simon Care and Feeding of Molded Fiberglass Trailers 23 04-06-2006 10:12 PM
Painting Ensolite Legacy Posts Problem Solving | Owners Helping Owners 23 07-08-2003 11:06 PM
Clean/Glue Ensolite walls Legacy Posts Modifications, Alterations and Updates 7 04-30-2003 09:35 PM
