Ensolite Alternatives?? - Fiberglass RV
Old 05-08-2014, 08:51 PM   #1
hudman's Avatar
Trailer: triple e
Hello everyone!
I'm new to this forum and new owner of a Triple E Surfside. it's an empty shell right now and we're looking forward to making it our own. At this point, I can't seem to find a lot of info on a GREAT Ensolite alternative that's reasonably cheaper.
Polyethylene seems to be fairly priced. Anyone had any luck with this stuff or anything else worked well?
Any input is greatly appreciated or direction to a great thread on the topic.
Chuck
ps. Will start posting picks of the reno shortly.
hudman is offline   Reply With Quote
Old 05-09-2014, 10:11 AM   #2
I used Reflectix and covered it with UV stabilized outdoor carpet. It worked well and carpet hides the seams. Buying two covers plus the adhesive to put both on added up.
I have also seen spray foam used, but the labour after to shape it seems too large to attempt.
Nelmes is offline   Reply With Quote
Old 05-09-2014, 10:19 AM   #3
hudman's Avatar
Trailer: triple e
Thanks Nelmes!
I was wondering if anyone had tried 'spray foam' with success as well. Seems like that would be tricky on getting consistent coverage.
I'll check out the reflectix stuff online shortly.
Thanks again!
Old 05-09-2014, 10:21 AM   #4
hudman's Avatar
Trailer: triple e
Anyone hear of Polyethylene closed foam as an alternative? Any luck?
Old 05-09-2014, 10:58 AM   #5
WADDYWOODSTOCK's Avatar
Kentucky
I used reflectix glued on with 3M spray adhesive and contact cement. Click image for larger version
Name:	ImageUploadedByFiberglass RV1399654664.682636.jpg
WADDYWOODSTOCK is offline   Reply With Quote
Old 05-09-2014, 11:37 AM   #6
David Tilston's Avatar
Why not use Ensolite:
Ensolite IUO Peel and Stick --- 1 yard (13.875 sq ft) - RAAMaudio Inc.
or
Ensolite IUO --- 1 yard (14 sq ft), Glue On version ( I recommend the PS version for most installs as far easier to work) - RAAMaudio Inc.
with
V&S Spray Adhesive, used for regular Ensolite or other glueing needs, do not use it on PS Ensolite or BXT II, not needed - RAAMaudio Inc.
Paint it with a good vinyl paint, with a big fluffy roller. Should end up like elephant skin. I just might try it on Humpty Dumpty.
Old 05-09-2014, 02:42 PM   #7
hudman's Avatar
Trailer: triple e
I like the look of the reflectix on the lower half of the shell interior... carpet the sides, then 'hardwood' the floors and I'm up and running there! Thanks for the pic!
David-I'm totally into the ensolite thing, as it is the best, and thanks for the links! I will probably go with that unless I hear of something else comparable. Do you know what thickness I should be looking for with Ensolite in our camper?
Is Ensolite pretty much a closed foam product, ie polyethylene? I only ask this as I found a place that sells 50ft rolls of it for aruond 120 delivered. IF not, then Ensolite it is and thanks for the help on the topic!!
Old 05-09-2014, 02:45 PM   #8
hudman's Avatar
Trailer: triple e
...and thanks for the pointer on painting with the roller, and a "good vinyl paint"
Old 05-09-2014, 03:09 PM   #9
Kentucky
Name:	ImageUploadedByFiberglass RV1399669747.678454.jpg
Here is floor with reflectix then sub than wood laminate
Old 05-09-2014, 03:27 PM   #10
hudman's Avatar
Trailer: triple e
That is money!! Looks great!! Definitely doing that for the lower half. Great job!!
Old 05-09-2014, 03:36 PM   #11
Chuck, I would say the stuff in my Trilliums is 1/8" thick, or thereabouts.
I am not sure I understand your question. Ensolite is a closed cell, black foam that is a fair to middlen insulator. It is heat resistant. It was originally used in aircraft.
50 feet for $120 sounds like a good price.
Old 05-09-2014, 06:46 PM   #12
Just don't get sucked into buying something cheap and they call it ensolite and it's really an open cell foam. Y'all know what happens right? There's a reason they used open cell foam for kitchen sponges.
Either way, the effort to put it on the wall is going to be the same.
Old 05-10-2014, 08:20 AM   #13
hudman's Avatar
Trailer: triple e
Thanks Donna, I'll be sure not to grab any of that!
Old 05-10-2014, 08:27 AM   #14
hudman's Avatar
Trailer: triple e
Yes, 50 feet for 120 delivered seems like a great price. It's from the foam factory, available in Canada and the USA. Closed cell, acoustic dampening, heat resistant, fire retardant, etc.. Seems like a decent product. Comparable...
"http://canada.foambymail.com/VA/polyethylene-foam-roll.html"
Haven't pulled the trigger yet on it. I might just order a small piece of both to compare and paint and see how the polyethylene holds up.
Thanks for all the input David!
Hot water heater alternatives? pindraak Problem Solving | Owners Helping Owners 7 01-03-2011 09:37 PM
alternatives to honda and yamaha generators lloyd cicetti General Chat 21 03-11-2009 05:50 AM
Alternatives to portable propane containers Booker B. Care and Feeding of Molded Fiberglass Trailers 46 07-31-2008 10:06 AM
Scamp 16: Front and Rear Window alternatives? Legacy Posts Problem Solving | Owners Helping Owners 2 03-14-2003 12:03 PM
