Ensolite replacement? - Fiberglass RV
Old 05-20-2018, 12:52 PM   #1
Microdad's Avatar
Trailer: 1978 Trillium 1300
I was looking at Home Depot web site to replace the ensolite in my trillium 1300 and found this.see pic. Any ideas or input?!Click image for larger version
Microdad is offline   Reply With Quote
Old 05-23-2018, 06:07 PM   #2
mat
Trailer: 73 Boler
really interesting stuff. mold and mildew resistant. if you end up using it let me know ill be in the market to do the same in a couple years. Questions would be can you put contact cement on it and can you paint it? Otherwise good price for the amount of product.
one review on the home depot web site did mention that it rips easily.
mat is offline   Reply With Quote
Old 05-24-2018, 03:22 PM   #3
Microdad's Avatar
It's not a question of if it's when. Lol it has a sticky back on it.
Old 05-29-2018, 10:28 AM   #4
Trailer: 1977 13' Scamp
That stuff looks great.
rexrogers is offline   Reply With Quote
Old 05-29-2018, 02:45 PM   #5
John in Santa Cruz's Avatar
Mid Left Coast
that kind of looks like its aimed at the car stereo sound damping market, as a replacement for the ridiculously expensive Dynamat.
Old 05-29-2018, 10:19 PM   #6
Trailer: Trails West
You might consider using the EVA foam yoga/gym mats. EVA foam is closed cell, it does not take up water. The mats are pretty tough, made to withstand some foot traffic on them. Not constant foot traffic but they don't tear that easily. The mats come in 1/8" or 1/4" thickness and come in a variety of colors. You can get it to conform to curves and even a gentle compound curve. EVA foam is a good insulator and it also helps deaden sound as well. It does not grow mold.
The interlocking floor mats people are fond of using for flooring in their trailers are also made of EVA foam but those mats are thicker than the exercise mats. But that would certainly be acceptable to put on the under-cabinet walls as it will cushion any shifting cargo that bumps into the sidewalls.
Contact cement or the upholstery spray that withstand high temps do work with it. Landau foam, the stuff they put on top of car exteriors to create those soft top roofs, is an EVA foam product. But it does not have a tough enough surface on its own without applying a headliner material over it. Landau foam in a 3/8" thickness is what I have put onto my ceiling for insulation. It has the special fuzzy backed marine vinyl over it. Not all marine vinyl can be applied with contact type cements. You will likely have to special order the right type as you can't obtain it off the rack at local fabric stores.
Old 05-29-2018, 10:31 PM   #7
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
"Raw" meaning no finished surface Ensolite foam:
https://www.scs-interiors.com/ensoli...-material.html
Ensolite with a skin on it:
https://www.foammart.com/p-456-ensolite.aspx
Ensolite replacement? Microdad Towing, Hitching, Axles and Running Gear 0 05-20-2018 12:40 PM
Ensolite replacement option - need help cityslicker Problem Solving | Owners Helping Owners 40 04-10-2015 03:43 AM
Wallcovering/Ensolite Replacement Possibility? Francesca Knowles Modifications, Alterations and Updates 2 06-11-2011 08:04 AM
ensolite replacement Lisa Rynearson Care and Feeding of Molded Fiberglass Trailers 5 04-10-2006 06:46 PM
Clean/Glue Ensolite walls Legacy Posts Modifications, Alterations and Updates 7 04-30-2003 09:35 PM
