Hi y'all
I have a 13'
Bigfoot. the entrance door has an aluminum frame surrounding the opening. at all 4 corners there is a plastic molding that couples the vertical pieces with the horizontal pieces. I have two of the trim pieces missing ( because they deteriorate, and break apart with little pressure ) the bottom front corner has been broken apart, when road gravel, has hit it.
Do you know if this type of part would be replaceable?
I will get a picture
and post it!
Later Kenny
