So, is it possible to simply replace the front panel?
The panel can be replaced, but IMHO it isn't simple. An analogy would be like replacing the bottom layer of a wedding cake. You'd have to remove the door from the trailer by disconnecting the hinges. Then disassemble the door from the inside out. There should be a join in the edge which, when disassembled, should release the layers of the door.
