Epoxy VS Polyurethane for giving a Smooth Finish to Epoxied Fiberglass Veil - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 06-13-2017, 06:33 AM   #1
Trailer: Canoe
This past weekend I took the time to refinish my Souris river canoe. The underside of the ribs was experiencing a lot of wear, so I contacted the rental store where I bought the canoe. Their maintenance guy suggested putting strips of fiberglass veil on the underside of the ribs while doing the epoxy coat.
I kind of regret this decision since the veil left a very rough surface on the underside of the boat. I am going to sand it down and refinish it. This being a lightweight (41lb) portaging canoe I would prefer to keep the weight down.
Looking for advice here. Will sanding the bottom of the hull and coating with polyurethane give me a smooth fast finish, or do I need to apply another layer of epoxy?
PS for anyone curious the boat is 90% Kevlar but the outermost layer is fiberglass which is why you can sand the outside.
PICTURES:
https://imgur.com/gallery/RELBq
Thanks
Al
LittleCleo is offline   Reply With Quote
vin
Epoxy, Gel Coat, Bondo, fiberglass repair KevinScamps Modifications, Alterations and Updates 17 09-27-2016 07:07 PM
Patch the fiberglass body, how to make it smooth HawkBoler72 Modifications, Alterations and Updates 8 06-05-2016 12:05 PM
Building a bunk.. Epoxy or PL ????? babs08 Problem Solving | Owners Helping Owners 7 03-15-2015 07:34 PM
Which epoxy/resin to seal belly band on Trillium? Gumpit Modifications, Alterations and Updates 4 11-10-2010 02:38 PM
an epoxy on both your houses Ian-Vicki Problem Solving | Owners Helping Owners 12 06-14-2008 09:20 AM
