Ethanol or Proplene Glycol - Fiberglass RV
Old 09-29-2009, 09:03 AM   #1
Trailer: 17.5 ft and 25 ft FB Bigfoot
I've been using ethanol based winter anti-freeze in my trailers for years with no apparant side effect. Just readying that it is no good for metal. I leave some sitting in the faucets and water pump and there may be other metal parts as well. Trying to get myself educated on proplene glycol based anit-freeze. Has anyoine had experience with both or have some goodcomparative literature I can read up on? Thanks.
Tamid is offline   Reply With Quote
Old 09-29-2009, 09:15 AM   #2
Chester Taje's Avatar
I use same type. I have never had a problem. Where did you read this info at?
Old 09-29-2009, 09:58 AM   #3
All the ethanol based anti-freeze jugs I've looked at indicate it can be corrosive to metal and shouldn't be used on metal parts in the plumbing system and can dry out the rubber gaskets. I've been checking various RV dealer sites about winterizing and they claim the same. Some will only use propylene glycol.
Old 09-29-2009, 10:04 AM   #4
DonDeutsch's Avatar
When you all are saying ethanol base you are refering to ethylene glycol right?
"The major danger from ethylene glycol is ingestion as it is somewhat toxic with LD50 = 1.4 g/kg for humans. Due to its sweet taste, children and animals will sometimes consume large quantities of it if given access to antifreeze. Upon ingestion, ethylene glycol is oxidized to glycolic acid which is, in turn, oxidized to oxalic acid, which is toxic. It and its toxic byproducts first affect the central nervous system, then the heart, and finally the kidneys. Ingestion of sufficient amounts can be fatal.[6]"
DonDeutsch is offline   Reply With Quote
Old 09-29-2009, 10:19 AM   #5
Raya's Avatar
I would heartily recommend using propylene glycol. It's non-toxic (don't drink it as a beverage, of course)*. Ethylene glycol is toxic.
(I don't know ethanol anti-freeze.)
Raya
*That said, if you have a relatively mild climate (i.e. it freezes but not crazy low), you might consider using vodka for potable water systems. We use this on boats in the mid-Atlantic because the propylene glycol can leave foaminess and a bit of an aftertaste. It does get down in the teens (F), but not much below that.
PS: We do use ethylene glycol in engines, but I'm talking about the water systems on a trailer, which presumably has no engine.
PPS: IMPORTANT: As Don notes, ethylene glycol has the scary and dangerous combination of being very delicious to pets and also deadly toxic. BE SURE not to leave ANY ethylene glycol where pets can get to it.
Old 09-29-2009, 10:28 AM   #6
Penney H. & Mike E.'s Avatar
Trailer: 2005 17 ft Escape ('Turtle')
Gasoline in urban areas contains 10% ethenol to reduce pollution. It is a type of alcohol - and alcohol will reduce the freezing point of water. Vodka is not 100% alcohol. What proof does your tailor prefer?
Mike
"A good traveler has no fixed plans and is not intent on arriving." -- Lao Tzu
Enjoy our travel photos at: Turtle Travels
Penney H. & Mike E. is offline   Reply With Quote
Old 09-29-2009, 10:32 AM   #7
Trailer: U-Haul CT13 ('Pearl')
SW Ohio
If you use vodka, is it an olive or a onion you need to add?
Pat B Ohio is offline   Reply With Quote
Old 09-29-2009, 01:24 PM   #8
Ethylene glycol is used as anti-freeze in vehicles. It is not for the plumbing systems of RV's or other. However there is an Ethanol based plumbing anit-freeze that my first post refers to. As for vodka the proof is too low. Why not try pernod? I have a bottle that is 70% proof. You could flambe right out of the faucet!
Old 09-29-2009, 01:28 PM   #9
Raya
Raya,
I understand that after about -25 C the propylene glycol can get somewhat mushy, like it is starting to freeze but the bursting point of often rated to -50 C depending on the brand and concentration. As for after taste the advertisement on some sites indicates there is no taste. Have you tried it and can you taste it?
Old 09-29-2009, 01:45 PM   #10
Just to confirm what I use.
http://www.recochem.com/en/index.php/produ...ne/item/premium
On my Jug it says all metal pipes including copper and plastics.
Old 09-29-2009, 01:49 PM   #11
Chester,
Just to clarify your first message. You are using a propylene glycol based product not an ethonal based product.
Correct? I've been using the ethanol based product and was thinking of switching ovet to propylene glycol based on what I've been hearing.
Old 09-29-2009, 02:09 PM   #12
Tamid
The jug says Quote---Premium . Super RV Plumbing Antifreeze End Quote.
On Caution label it says Contents may catch fire.(CONTAINS ETHANOL.) Do not smoke. Do not get in eyes. Use only in well ventilated area. Keep away from flames, such as pilot light , and any object that sparks, such as electric motors.
Interesting Caution Label
PS---No Mention of propylene glycol
Old 09-29-2009, 02:44 PM   #13
Gina D.'s Avatar
West Coast USA
propylene glycol is an FDA approved ingredient for human consumption in many foods (Lots, actually) as a moisturizing agent. Go check your toothpaste tube.. its in there.
The only reason I know this is because I am Electronic Cigarette user, and PG is the ingredient used to actually create the "Smoke" or vapor effect (PG is used in Fog machines which spew the vapor on hundreds of folks at a time) You can be darned sure I checked, double checked and triple checked that PG was safe before I started using one.
I am not an antifreeze expert, but if it was PG based, I would have no problem using it, at least for the health aspect.
Old 09-29-2009, 03:25 PM   #14
Tamid
Chester,
Went back to the link you provided and the advertising blurb says the product is a combination of propylene glycol and ethanol. Interesting mixture. Instead of making a totally non-toxic product they've decided to make a half toxic product.
