Exceedingly basic battery question - Fiberglass RV
Old 04-23-2015, 07:26 AM   #1
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
I took the battery out of our Scamp to store during its first winter and foolishly neglected to mark the wires. The Scamp manual and electrical video are not helpful on which wire goes to the positive terminal. I think it is the black (with short yellow section and fuse on the end) wire and the white wire is negative. I would appreciate a confirmation before I make the connection and risk blowing a fuse or worse.
Spring is slowly creeping up to Vermont and we're looking forward to our first full season of scamp adventures.
Many thanks.
WDavidG is offline   Reply With Quote
Old 04-23-2015, 08:00 AM   #2
You didn't mention how old your Scamp is; if it is more than a few years old, it's hard to tell what a previous owner might have changed.
While the color code and the presence of a fuse are good clues, I'd still follow wires out to find which one is the ground side, it's usually a fairly short wire.
Old 04-23-2015, 08:12 AM   #3
Vermont
It's new, 13', - picked up from the Backus factory last June
Old 04-23-2015, 08:15 AM   #4
Raz
Raz's Avatar
Vermont
In the RV world black is positive and white is negative. Putting them backwards might cause the cheaper LED's not to light, and motors to turn backwards. Plugging into the tow would pop the fuse. Raz
Old 04-23-2015, 08:17 AM   #5
David Tilston's Avatar
I figured out that I had it backwards when I switched my converter from shore power to battery. My vent fan stopped then reversed. Oops.
Old 04-23-2015, 09:19 PM   #6
Vermont
Thanks all - appreciate the advice. I'll go with black/yellow to positive.
Old 04-24-2015, 10:11 AM   #7
Briantb's Avatar
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
There should be a sticker right above the battery box with the connection info
Sent from my XT1028 using Fiberglass RV mobile app
Briantb is offline   Reply With Quote
Old 04-24-2015, 10:15 AM   #8
Briantb's Avatar
New Brunswick
Sticker on Scamp above battery box
Old 04-24-2015, 10:16 AM   #9
Scamp trailer wiring is like house wiring. The negative (neutral in the house) is white, the positive (hot in the house) is black. As was mentioned my 2006 13' has a sticker on the front of the trailer.
NOTE: Nasty things can happen if connected backwards, fuses can blow, converters and be damaged, and it plugged into the tow alternators can be damaged.
Old 04-26-2015, 08:00 AM   #10
Vermont
Oh my, I'm certainly feeling foolish this morning. As several of you pointed out, with pics no less, the instructions are right there in plain sight. My only defense is that when I posted the question the Scamp was still wearing her winter coat. I removed the cover this morning and the label was obvious.
Thanks for your replies and patience.
David
Old 04-26-2015, 08:41 AM   #11
Raz
Raz's Avatar
Vermont
Yeah, I hate when that happens. But It does make my wife feel good when she can point things like that out. By the way I'm just south of Barre. Cold and cloudy here. Any better where you are? Raz
Old 04-26-2015, 09:19 AM   #12
Vermont
Alas, no better here in the Connecticut valley. T.S. Eliot was right about the cruelest month - maybe he was a Vermonter!
Old 04-26-2015, 04:46 PM   #13
Briantb's Avatar
New Brunswick
My first year with a Scamp I didn't see it either.. I recalled there was a sticker but do you think I could find it.. Once you slide the battery box cover all the way off
battery
Basic questions ;electrical from a new owner Kent I Electrical | Charging, Systems, Solar and Generators 11 12-07-2010 07:57 AM
13' Scamp basic electrical question Nick Glenney Problem Solving | Owners Helping Owners 3 04-05-2009 08:55 PM
I need a recommendation for a basic electronics book Judith K. Care and Feeding of Molded Fiberglass Trailers 10 02-16-2009 06:24 PM
Nice deal on a good basic GPS peterh General Chat 8 02-26-2008 11:13 PM
EXTREMELY BASIC question General Chat 0 12-31-1969 07:00 PM
