External Electrical AC Outlets - Fiberglass RV
Old 05-06-2008, 05:42 AM   #1
Trailer: 2013 Escape 19
I recently posted these questions as a follow-on to my topic on converting a window AC unit to sit outside the camper, but I don't think they were noticed. Besides, it's probably a more general question about external power connections. For those with exerternal AC units, or other external appliances, do you plug directly into the campsite outlet (maybe through a tee where the trailer line connects) or do you install an outlet on the outside of the trailer? What about a GFI? Do you count on the campsite having safe grounds, or do you install your own GFI unit? The Pet Cool unit I had with the teardrop used a simple grounded 110V plug, apparently not concerned with the elements. I suppose the best way would be to at least use an external outlet box with a rain cover. Of course if I run straight to the campsite outlet, that's usually covered. Comments appreciated.
Parker Buckley is offline   Reply With Quote
Old 05-06-2008, 05:56 AM   #2
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
My Casita came with an outside outlet on the door side. That outlet is wired into the distribution box in the trailer. What I have is one of those surge protector/GFI plugs I use at the end of my shore power cord that plugs into the power pole.
Surge/GFI
In the grand scheme of things I don't know what it's worth in terms of surge protection but it's my understanding that anything downstream from a GFI is protected.
Without adult supervision...
Also,
Old 05-06-2008, 06:45 AM   #3
james kent's Avatar
Trailer: Boler 1984
After a battery charger had meltdown I carry one of those economical little outlet testers and check the campsite source before I plug in. I have found the camps wiring wrong on a couple of ocasions.
"Oh it's OK just go ahead and plug your trailer in.
Then You'll pay for any damage done to my trailer, Right?"
Now that you bring it to my attention, it would be a good idea to replace at least the original household type outlet on the outside where we connect a coffee maker or electric frypan with a GFI. BUT then I'm sitting on rubber tires, isolated from a true ground except for the camp ground. Mabee a surge protector would be better. I think I need an electrician.
Old 05-06-2008, 06:54 AM   #4
Steve's surge protector/GFI unit looks attractive. I hadn't really considered the surge protection...I was more interested in protection from unsafe wiring (poor grounds) in the campsite. Also, just from a general point of view, whether or not people worry about having extension cords or external 110V connections using without some sort of weather protection. I think I'll at least get a GFI somewhere in the string. I don't want my (or anyone else's) body to provide the ground circuit for the air conditioner. Curious to see what other experiences may be.
Parker
12V DC outlets? pindraak Fulltiming in a Molded Fiberglass Trailer 29 03-17-2011 08:44 PM
Need info about adding more AC outlets Vickie B. Electrical | Charging, Systems, Solar and Generators 11 10-21-2010 09:04 PM
New external hatch Roddy D Modifications, Alterations and Updates 12 07-29-2009 11:12 PM
can't remember if my outlets are AC or DC lloyd cicetti General Chat 3 05-18-2009 08:14 PM
110 Outlets In a 16' Spirit Deluxe Legacy Posts Problem Solving | Owners Helping Owners 11 11-05-2002 06:04 PM
