Fabricate propane access cover - Page 2 - Fiberglass RV
Old 07-30-2014, 11:14 PM   #15
FTTRV's Avatar
Trailer: tp
I just replaced the same thing on a Sunrader Motorhome. Door not available but the compete door and frame is available. The one I bought cost 49.00. It took about one hour to change out.
Chuck
Old 07-31-2014, 12:38 AM   #16
AKscamper's Avatar
Trailer: 1987 Scamp 13'
Alaska
Thanks Steve, that helps. Looking at this one and measurements seem to match.
Norcold 617484PW Refer Service Vent Door Polar White
AKscamper is offline   Reply With Quote
Old 07-31-2014, 12:41 AM   #17
AKscamper's Avatar
Alaska
Wonder if my fridge is a Norcold, there isn't much to identify it with
Old 07-31-2014, 12:43 AM   #18
AKscamper's Avatar
Alaska
A google search says it's a dometic:
https://www.dometic.com/ed505e90-e10...ee053651.fodoc
Old 07-31-2014, 12:49 AM   #19
AKscamper's Avatar
Alaska
http://www.adventurerv.net/dometic-r...e-p-11445.html
Steve, does this look like it would fit your 1986?
Old 07-31-2014, 03:48 AM   #20
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Originally Posted by AKscamper View Post
Dometic Refrigerator RM2354 Access Door/Panel/Vent Exterior Polar..
Those folks at adventure rv are great. I've bought a lot of stuff from them, and they are very helpful over the phone when you have questions.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 07-31-2014, 08:51 AM   #21
Dometic Refrigerator Exterior Vent Bright White 8030211322 | eBay
Old 07-31-2014, 08:57 AM   #22
When you open the vent it rotates up. rotate all the way up and push back slightly it unhooks from the frame. Hopefully the new door will hook into the old frame. Otherwise you will have to change out the frame too. Then you will also need a roll of real butyl tape and screws to mount the new frame.
Old 07-31-2014, 04:53 PM   #23
AKscamper's Avatar
Alaska
Great, I was hoping the new cover would just pop right in without having to redo the whole frame. Turns out my hometown rv store, Karen's has the cover. Who knew...
I sure appreciate this forum to get me headed in the right direction.
Old 07-31-2014, 04:56 PM   #24
AKscamper's Avatar
Alaska
Steve, since you have a 1986, do you have a furnace and convertor? My last major issue (I think) is the wiring of the convertor. It's been pulled out for some reason and left disconnected. I don't want to plug in to a shore line until I fix it. I'm wondering if someone has the same convertor if you are able to see which wire connect to each other. I can attach a pic...
Old 07-31-2014, 04:57 PM   #25
AKscamper's Avatar
Alaska
Name:	ImageUploadedByFiberglass RV1406847424.753729.jpg
Old 07-31-2014, 05:47 PM   #26
Roy in TO's Avatar
The instructions seem to be clear on the door in the picture.
Old 08-01-2014, 08:50 AM   #27
My Scamp didn't come with a converter it came with a 12 volt system and a 120 volt system they were not connected and had no battery charge functions. I rewired my trailer and put in a modern Progressive Dynamics PD4045 it has smart charger and can be left plugged in and not cook my battery.
My trailer didn't have a heater when i bought it so I installed an Atwood 2 model 7912-2 for high efficiency and lowest 12 volt power draw.
propane
bigfoot trailer propane cover and tire cover biggoolies Classified Archives 3 11-12-2011 08:25 AM
Bigfoot Propane Bottle Cover Access Tim D. Modifications, Alterations and Updates 2 04-17-2011 05:57 PM
Vent Cover and Power Outlet Cover Todd Sleeman Classified Archives 0 11-30-2008 05:29 PM
Access to propane tanks Lainey Problem Solving | Owners Helping Owners 5 08-09-2007 03:29 PM
To cover or not to cover, that is my question?! Legacy Posts Care and Feeding of Molded Fiberglass Trailers 33 06-05-2003 07:49 AM
