Fantastic fan - Fiberglass RV
Old 04-28-2013, 07:19 AM   #1
Trailer: 2010 SCAMP
Fantastic fan
Trying to find info on my fantastic fan. While camping and plugged up to 30 amp, the fan slowly stopped. All other electric fine.
Thanks,
Emily
pageleigh is offline   Reply With Quote
Old 04-28-2013, 07:23 AM   #2
Mike Magee's Avatar
Trailer: Li'l Hauley
If the fan is malfunctioning, the FF mfr will probably replace it for free. I've heard that they have fantastic customer service.
If you could check with a tester to see if power is still present in the wires leading to the fan, that will narrow it down.
How to prepare Tofu
Step 2: grill some meat
Old 04-28-2013, 07:34 AM   #3
Trailer: 2010 SCAMP
Thanks Mike
Old 04-28-2013, 10:18 AM   #4
Perry J's Avatar
Trailer: 16' Casita
30 amp service does not mean that your fan was using all 30 amps.
30 amps ARE AVAILABLE if you have many appliances running at one time that, combined, need 30 amps.
Old 04-28-2013, 12:07 PM   #5
carlkeigley's Avatar
NE Oklahoma
My Fantastic Fan is 12vdc.
Old 04-28-2013, 12:50 PM   #6
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Could be a blown fuse. Could be a bad switch in the fan itself. Does it have a thermostat? That would make it shut off by itself.
Old 04-28-2013, 05:08 PM   #7
Trailer: Bigfoot 1981 Trailer
Thanks,
Emily
If the vent is closed, or even party closed, the fan will stop. Hope this helps. Jim
Old 04-28-2013, 05:13 PM   #8
Raz
Raz's Avatar
Vermont
Check the fuse on the fan and the fuse at the distribution panel. Also try "working" the switches ( turning them off and on). A dirty switch will sometime briefly come on, indicating it needs cleaning. Raz
Old 04-28-2013, 05:41 PM   #9
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Does it have a thermostat? My Maxx fan has one and if set for thermostat control, as the temperature in the trailer drops, it slows down & eventually stops.
Old 05-01-2013, 10:17 PM   #10
NE Oklahoma
When we picked up our trailer, the fan worked great on the way home.
This week we went out again and the fan did not work. The light on the switch did not work. I was a bit frustrated. The daughter flipped it on in camp and it started working and the switch light was working. Later I turned it on and the fan still worked but the light on the switch didn't work.
I guess a new switch can be dirty? Or just faulty.
Old 05-01-2013, 11:24 PM   #11
Too many assumptions here. First what does "All other electric fine." Did you actually try the 12 lights?
The battery charges when you tow, hence worked for awhile worked great on the way home. "Went out again and fan did not work." Didn't work at first, didn't work after running a while,?
Remember the fan runs off the 12 volt system. If the converter is turned off, fuse blown, circuit breaker tripped, then the battery will run down and the fan will stop working.
Old 05-02-2013, 05:59 PM   #12
NE Oklahoma
On mine, the lights (12v) worked fine.
I'm thinking my unit has a problem in the control panel.
Haven't checked it yet.
Don't know if OP has resolved theirs yet.
Old 05-02-2013, 06:39 PM   #13
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I had an inside overhead 12 volt light and the outside entry light that worked now and then. It turned out to be a "scotch-lock" connection under the curb side dinette that had caused the problem.
Old 05-03-2013, 12:26 PM   #14
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Imagine that. If I ever meet the guy that designed those, he's going to get a swift kick in the rear.
New Fantastic Fan going in... dylanear Modifications, Alterations and Updates 49 08-30-2014 08:51 PM
For Sale: Fantastic Fan (New) LagunaDirt Parts: Buy | Sell | Trade 0 02-16-2013 07:31 PM
Fantastic Fan question Sandra Lair Problem Solving | Owners Helping Owners 5 07-22-2008 10:07 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Roger Harshaw Problem Solving | Owners Helping Owners 4 03-15-2008 12:47 AM
