Fantastic Fan - Fiberglass RV
Old 10-10-2014, 01:45 PM   #1
Trailer: U-Haul
Fantastic Fan
Hi all,
Can anyone assist me with determining which Fantastic Fan will fit my 1984 U-Haul? I saw on another forum that there is a low profile lid, and also different depth(s) on the unit depending on the roof thickness.
Any input is greatly appreciated.
Nrody is offline   Reply With Quote
Old 10-10-2014, 03:58 PM   #2
Trailer: Escape 5.0 TA
forget the fantastic fan
I suggest you get a maxxfan. It fits the same hole as most vents and fans. It has an aerodynamic lid that is low profile and can be left open when its raining. Although I think its unnecessary, its available with a clicker for control. I replaced my fantastic fan with the Maxxfan. I do have another use for the fantastic fan but I really like the Maxxfan on my Casita!
starbrightsteve is offline   Reply With Quote
Old 10-10-2014, 06:10 PM   #3
Trailer: 16' Scamp
Wyoming
We used the basic Fantastic fan on our Scamp. The roof is so thin that I couldn't use the supplied trim ring but ran screws thru fan frame,butyl tape, the roof and into a frame of oak 1x2 boards.
Will
Wyowill is offline   Reply With Quote
Old 10-10-2014, 07:19 PM   #4
I can't remember which model I used but it works good on our Uhaul. I'm away from home for the weekend, will look it up when I get home. The Uhaul has a raised section there on the roof and plenty of thickness for the screws. Like I said on tnttt, I had to cut down the vertical part of the inside trim ring. I may still have that piece to measure. You would only need a low profile lid if you have a clearance problem, like moving the trailer into a garage.
mary and bob is online now   Reply With Quote
Old 10-10-2014, 08:18 PM   #5
They do have one designed for use on trailers such as ours with thin roofs. Call them and they will be able to tell you which it is.
I used a standard one and just mounted it flush to the roof and on the inside I trimmed it with wood the same as what Scamp used around the big escape hatch ahead of it. The little drop down from the trim is not a problem as its located in the center over the rear dinette/bed.
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 10:43 AM
Fantastic Vent Still Fantastic Thomas G. General Chat 1 06-27-2013 02:59 PM
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
fantastic or non fantastic? Flygal General Chat 16 04-07-2010 09:53 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
