Fantastic fan flange install - Fiberglass RV
Old 07-03-2009, 01:10 PM   #1
Pat C's Avatar
Trailer: 1981 Boler 13 ft / 2005 Dodge Caravan
We installed a fantastic fan/vent about a year ago.Never got around to putting the finishing flange on the inside.I have spacers sent from the Co.and a sized down flange so everything is ready to put up.HOWEVER I am unsure about using screws provided to install this.What have others done.I am positive that any screw used will go through the roof.Thanks...Pat.
Pat C is offline   Reply With Quote
Old 07-03-2009, 03:58 PM   #2
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
My flange went unfinished for a couple of years. As my trailer is painted, as opposed to gelcoat, I decided to add the spacer outside, on top of the roof. Being painted, I can easily hide my mistakes.
Two 3/4 inch plywood cutouts sandwiched together with fibreglass and resin. I then was able to flush mount the flange on the inside. gives that little extra headroom. I could then put screws,from the inside, through my roof directly into the fibreglassed plywood.
I will be posting a video shortly.
kevin61 is offline   Reply With Quote
Old 07-03-2009, 06:14 PM   #3
Trailer: Fiber Stream
Talking
I added a wood frame made out of 1 x 2 inch poplar between the "flange" and the ceiling.
Old 07-03-2009, 06:59 PM   #4
Pat C's Avatar
Hi Fredrick, How did you attach the wood frame to the ceiling? That is my problem,I am not keen on screwing something to the ceiling. Did you use screws and if so what size? Pat.
Old 07-03-2009, 07:26 PM   #5
Trailer: Trillium Jubilee
Could someone use something like Liquid Nails to glue it?
Marc is offline   Reply With Quote
Old 07-03-2009, 09:23 PM   #6
Talking
First, note that I do not have any interior covering. My interior is just paint on the inside of the fiberglass.
I used Gorilla Glue. It needs to have pressure applied while the glue sets. I used a piece of plywood and a 2x4 braced against the floor to press the glued frame against the ceiling for 24 hours.
Old 07-04-2009, 11:16 AM   #7
Pat C's Avatar
Glueing sounds good.Think I will try that.Does anyone have a suggestion as to what glue will bond well on the ensolite?Something that is available in Canada.Thanks.
Old 07-05-2009, 09:18 AM   #8
kevin61's Avatar
After having my Fantastic Fan installation remain unfinished for a few years I decided to add a spacer on top of the roof in order to keep it flush with the ceiling on the inside.
Old 07-05-2009, 09:43 AM   #9
Unhappy
I fear that a wood spacer would not bond well to the ensolite; it would be too heavy and either come unglued or pull the ensolite away from the fiberglass.
If it were me, I would pull the ensolite back a little bit, and bond the wood directly to the fibreglass. Then I would trim the ensolite to butt snugly against the wood.
Butyl tape under flange, then rivets or screws, + sealant ??? Guy, Boulianne Problem Solving | Owners Helping Owners 7 06-29-2010 07:09 AM
Fantastic fan install John Clayton Problem Solving | Owners Helping Owners 6 04-02-2010 09:46 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 04:58 PM
Fantastic Fan install questions TonyL Problem Solving | Owners Helping Owners 18 02-28-2006 06:59 AM
