Fantastic Fan install - Fiberglass RV
Old 03-30-2011, 07:45 PM   #1
Gordon Kinslow's Avatar
Trailer: Boler 1300
I want to install a Fantastic fan in my 13' Boler. The problem is I do not have battery power for the 12Volts required to run the fan. Is it feasable to wire an appropriate AC/DC adaptor to it.
Gordon Kinslow is offline   Reply With Quote
Old 03-31-2011, 12:08 AM   #2
Matt in SV's Avatar
That is actually what a converter is. You could buy a converter (modern converters like Progressive Dynamics products, don't require a battery in circuit to operate). Or maybe you could find a 12vdc power supply at a computer or electronics surplus. You'll need 4 to 5 amps. Check the fan specs.
Regards,
Matt
Planning our next Escape!
Old 03-31-2011, 01:41 PM   #3
Lizbeth's Avatar
I'm pretty sure they make a 110v model. The company is great, give them a call.
800-521-0298
Old 03-31-2011, 01:43 PM   #4
Lizbeth's Avatar
Yep, here it is
fantastic fan 110 volt fantastic vent adohen Supply
That's the best site ever for information besides the company.
Old 03-31-2011, 04:22 PM   #5
Matt in SV's Avatar
Excellent find!
Regards,
Matt
Old 03-31-2011, 05:58 PM   #6
Here's my 2 cents:
With the 120VAC you can only use it when you have shore power.
With the 12VDC model you can use it with shore power and battery power. You will appreciate the battery powered model when you are boondocking or overnighting at a Wallyworld.
Old 04-01-2011, 09:37 PM   #7
Check the FAQ on the Fantastic Vent website. The 110 versions of 4,5, and 6000 models are available, but do not have the reverse feature. I'd miss that, personally.
Matt's suggestion of the 5 amp convertor might just give you the best of both worlds.
Sherry
Fantastic Fan Install & Heater Repair barryra Modifications, Alterations and Updates 25 02-19-2011 09:31 PM
Fantastic fan install John Clayton Problem Solving | Owners Helping Owners 6 04-02-2010 09:46 PM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 04:58 PM
Fantastic Fan install questions TonyL Problem Solving | Owners Helping Owners 18 02-28-2006 06:59 AM
