Fantastic fan orrrr the Max air fan? - Page 3 - Fiberglass RV
Old 08-12-2016, 09:00 PM   #29
Originally Posted by The Minimalist View Post
I would much prefer to buy 'Made in the US'. Finding it is the trick.
You'll find lots of "Made in the USA' paperwork, and software.
Old 08-12-2016, 09:18 PM   #30
Madison, Wisconsin
I added two resistors to my FF to lower the noise and speed. Worked well. Then I got to thinking. The resistors made lots of heat and didn't save my battery. So I bought a PWM speed controller on Amazon ($4.00) and now i have variable speed, less noise and less battery draw. Win/win/win.
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 08-18-2016, 04:13 AM   #31
Tim D.'s Avatar
Trailer: 1991 17 ft Bigfoot
anystate
On the topic of Fantastic Fan vs. Maxxair: I have had a FF in my van for years with no problem. I have a Maxxair in my Bigfoot. I love the many speeds of the Maxxair but have had to deal with problems.
1) If the lid is not cranked up all the way it rattles in the wind.
2) After 5 years I replaced the printed circuit board, which failed due to corrosion, for $70+. I expect to replace it again some day as it is not adequately protected from the weather.
3) The design does not keep out mosquitoes. Tabs that holds the removable screen have gaps large enough that mosquitoes get through. The gap between the garnish and the face plate may also allow ingress. To solve the problem I installed removable no-see-um mesh to the garnish using Velcro on the garnish and on the mesh. I apply the no-see-um mesh when necessary. The fan works harder to move air but the bugs do not get in.
4) With the lid raised, during a downpour rain bounces off of the roof and into the fan. A steady mist enters the trailer.
5) The unit does not vent well without the fan blowing.
Despite the shortcomings I would buy the Maxxair again. I like the low profile when the lid is closed. For the FF to be open in the rain requires a high-profile vent cover. Rain may blow through the louvres on those covers when the wind is blowing from behind the trailer. The Maxxair under-lid area, prone to mold, is easy to clean by unhooking the raising mechanism, though you do need to be on the roof to do it.
1991 Bigfoot 17 Rear Bath
2006 Dodge Sprinter
Tim D. is offline   Reply With Quote
Old 08-18-2016, 06:46 AM   #32
cpaharley2008's Avatar
Good comparison write up....Tim.
Jim
Never in doubt, often wrong
Old 08-18-2016, 07:15 AM   #33
DonnaMarie's Avatar
Trailer: 2013 Lil Snoozy
problems with your maxxair fan...
So very sorry you've had these difficulties with your fan, but thank you, for explaining it all so well. Just curious...is your fan installed on the roof, on the wall...where? Thanks again!
DonnaMarie is offline   Reply With Quote
Old 08-18-2016, 02:55 PM   #34
Tim D.'s Avatar
anystate
Thanks, Harley.
DonnaMarie, the Maxxair is installed on the roof in the main cabin. The problems it has are not dealbreakers for me. As I said, I would buy the fan again.
One way or another I need to be able to open vents in the rain. My windows are sliders that let in the rain. Sometimes I can get away with opening them on the lee side, but then I must monitor wind direction.
My 9" bathroom vent has a standard plastic high-profile vent cover. I must monitor the wind direction when I leave that vent open during rain, as wind coming from behind the trailer will blow water through the vent cover louvres. That is the reason I stick with the Maxxair. Rain causing a mist to come in through the Maxxair only occurs during heavy, heavy rain.
I have lots of watts in solar panels so I do not mind that I must run the fan to achieve adequate ventilation.
Old 08-18-2016, 03:11 PM   #35
On mine, if you push up ( or pull down - can't remember ) on the knob used to open the vent, it locks in place and won't be bouncing up and down while traveling.
Old 08-19-2016, 04:19 AM   #36
DonnaMarie's Avatar
your maxxair fan..
Thanks, Harley.
Thank you for the clarity Tim!
Old 08-19-2016, 06:41 AM   #37
Tim D.'s Avatar
anystate
Glenn, locking the raising knob does lock the lid in terms of raising and lowering. At least on mine it does not stop the rattle. I contacted Maxxair, before the company was sold to Coleman. Customer support acknowledged the problem. Their solution: raise the lid to maximum height.
Old 04-20-2017, 11:32 AM   #38
Name: Billy Sharpstick
Trailer: Burro - '99 wide body 14
Maxxair models
This thread has comments about "the" Maxxair and "the" Fantastic. I just spent three hours wading through the specs for dozens of models for both. There are some pretty drastic differences. Here is a table for the Maxxair models: http://www.old.maxxair.com/oem/search2.php and Fantastic: Fan-Tastic Vent's Retail 12 Volt Fans
Also bear in mind that both of these companies have old models and new models, many of which are similar in some respects, but have totally different model naiming systems.
(BTW, I settled on the Maxxair 6201K.)
sharpstick is offline   Reply With Quote
Old 04-20-2017, 12:05 PM   #39
Should have gone with the 7500K, remote is nice to have by the bed and with the smoke lens lets more moon and natural light in.
Jim
Old 04-20-2017, 01:47 PM   #40
IllAnnoy
I like the maxxair and if I thought it was a better choice you can bet Eggy-Sue would have one.
My trailer came with a Fantastic Fan with a lifetime warranty. It has worked perfectly for 13 years now. I see nothing in the Maxxair to justify the change. With the addition of the vent cover and the window louvers, it works perfectly in hard rain and windy conditions.
Below is a photo which shows the type of vent cover which allows full opening of the vent and prevents even wind blown rain from entering.
As for profile it blends well with the low profile Mini-Mach A/C.
The widow louvers work well to keep the rain out on my sliders and add an attractive touch of style.
Old 04-20-2017, 02:30 PM   #41
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: sharpstick... Good choice!!! Here's pic's of the MaxxFan I put in our former Boler.
Old 04-20-2017, 02:37 PM   #42
Looks nice. Is the smoked cover translucent or opaque? I liked the light coming in through my old one.
Installing Maxx Air Fan Mate 850 Vent Cover Over Fantastic Fan CampyTime Modifications, Alterations and Updates 7 10-10-2013 11:43 AM
Max-Fan vs Fantastic Ron F Modifications, Alterations and Updates 34 07-31-2013 11:05 AM
Can I tow a 17' Burro with a 2000lb max trailer weight & 32' sq. max area Jared Sartee Towing, Hitching, Axles and Running Gear 8 07-22-2013 11:12 PM
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 05:25 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 12:33 PM
» Virginia Campgrounds
