Fantastic vent - Fiberglass RV
Old 06-21-2012, 09:27 PM   #1
GaryG's Avatar
Trailer: 89 13' Scamp
Fantastic vent
Hi All,
Ran into an issue with my 89 Scamp13. Trying to install fantastic vent. It calls for a 14" cutout. My Scamp came with a 2 speed vent fan,but the cutout is only 13.5" after removing. Any ideas on how to trim .25 inches from each side of cutout? I'm afraid to use a jigsaw for fear it may crack the fiberglass. It's pretty flexible up there. Any help greatly appreciated. Thanks, GaryG
GaryG is offline   Reply With Quote
Old 06-21-2012, 09:41 PM   #2
Roy in TO's Avatar
An angle grinder with a course sandpaper disc will do it in less time than to get the tools out and put them back.
Or you could just cut 1/2 inch from 2 sides.
Old 06-21-2012, 09:43 PM   #3
Trailer: Trillium 1300 Nor'Easter Egg '06 Ranger Supercab 3.0L auto
Newfoundland
You could try clamping 2" wide strips of 1/2" plywood on the inside and outside edges of the hole - measure the desired opening carefully, mark on the outside ply, and cut along that line with a fine-toothed jigsaw. I'd keep the clamps positioned near the blade, so the fiberglass edge is sandwiched between and supported by the ply strips. The clamps would have to be moved as you work along the cut, and should keep the ply strips snug against the fiberglass.
Richard Hayes is offline   Reply With Quote
Old 06-21-2012, 10:43 PM   #4
LukeP's Avatar
Iowa
have any friends who own a dremel tool? very clean cut, it'll take you about 2 mins.
I started cutting in my vent with a jigsaw and there was too much vibration. finished with the dremel and it was a breeze.
LukeP is offline   Reply With Quote
Old 06-21-2012, 10:53 PM   #5
Roy in TO's Avatar
Luke,
What did you use in the dremel?
Old 06-22-2012, 04:49 AM   #6
Trailer: 2007 Eggcamper
Roto-Zip (same as dremel tool) works great.
Art.
artspe is offline   Reply With Quote
Old 06-22-2012, 06:22 AM   #7
Trailer: 2014 Escape 21, Lil Joe
I would use a fein tool or other brands are available. While cutting I hold a shop vac hose near the cutter blade. This will capture most of your fiberglass dust.
Eddie
Eddie Longest is online now   Reply With Quote
Old 06-22-2012, 07:45 AM   #8
cpaharley2008's Avatar
a wood file would work, you only need a 1/4" all around which is not that much to file.
Old 06-22-2012, 07:51 AM   #9
LukeP's Avatar
Iowa
Originally Posted by Roy in TO View Post
Luke,
Roy,
I'm not at home to double check - but it was a cutting wheel that would have been similiar to this:
Heavy Duty Cut-Off Wheels (.040 in. thick, 20 per pkg.)-420 at The Home Depot
I'd never used a dremel much before working on my Boler - and then only really thought of it for intricate grinding, sanding, etc.
After I figured out how easily it cuts the fiberglass, I've used it many times since in the camper and in the house.
Old 06-22-2012, 09:43 AM   #10
Tim Wood's Avatar
Trailer: 2006 17' SD Casita
NY
I would have used an angle grinder like Roy, but I will admit the Dremel would be easier to manage. And with that cutoff wheel in it, a piece of cake.
Old 06-22-2012, 11:00 AM   #11
Roy in TO's Avatar
Thanks Luke,
I was thinking it might be something like this that is in my "generic dremel" kit. I have both.
Tim,
I've got a 4-1/2" angle grinder that I used to trim the edges on my boler door to make the gap even. Very easy to handle.
Old 06-22-2012, 11:04 AM   #12
Trailer: 77 Scamp 13
I like the ideas for dremal, angle grinder and just sand or file it.
I do figure it's worth mentioning the upcut jigsaw blade, since the teeth are angled toward the shoe rather than down the blade tends to pull the work toward the saw and you get less vibration. That and some masking tape along the cut can help with chipping and splintering.
Old 06-22-2012, 11:07 AM   #13
Tim Wood's Avatar
NY
Roy, Yep I also have a 4 1/2" grinder, but haven't used it on fiberglass yet. I do have a diamond tipped wheel and have used it on many thing though.
Old 06-30-2012, 02:57 PM   #14
Robert Johans's Avatar
Trailer: Nest Caravans
Oscillating Multi-tool works for me...
« Light | Theft?! »
Fantastic Vent upgrades.... cpaharley2008 Modifications, Alterations and Updates 19 01-17-2012 05:54 AM
Fantastic Vent upgrade cpaharley2008 Modifications, Alterations and Updates 5 06-18-2011 12:17 PM
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
Fantastic Vent for sale Craig Broughton Classified Archives 0 04-01-2009 02:46 PM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
