FantasticFan solution - Fiberglass RV
Old 05-25-2006, 11:38 AM   #1
Hi all:
I needed to clean the underside of the vent cover over my FanTastic fan (garden variety 3-speed reversible with automatic stock-market updates ). Six years of wonderful Oregon weather had finally produced a little dirt and the beginnings of black mold under the flap. I preferred not to climb on top and undo the Maxx cover, so the option was to clean it from the inside.
Using a long 3/32" Allen wrench ground to a usable length I managed to get the screw out, but then the fan blades absolutely refused to be wiggled free from the shaft. I called the company (nothing garden-variety about THEIR customer service!) and they suggested a penetrating oil as a first step. That didn't work, so I cobbled together a wooden version of a custom-sized gear puller from a disc of plywood, 4 threaded inserts, and 4 hex bolts. Easy if you have a drill press handy.
To my amazement the fan assembly pulled off with hardly a sneeze and enabled me to do the job. Slicker than snot, if you'll pardon the expression.
If anyone has faced this little problem let me know and I can fill in the details.
Our air conditioning solution CindyL Modifications, Alterations and Updates 16 06-10-2009 05:07 PM
Best cleaning Solution for.... remington850 Problem Solving | Owners Helping Owners 7 06-27-2007 10:26 AM
Awning solution Faith Modifications, Alterations and Updates 8 04-10-2007 10:14 PM
Neat bug solution CindyL Problem Solving | Owners Helping Owners 8 08-30-2006 10:05 AM
Another Solar Solution Jeanne and Steve Modifications, Alterations and Updates 6 05-27-2006 10:25 AM
